States Sue EPA on Outdoor Wood Boilers
Discussion in 'OWB's and Gasification Boilers' started by Teutonicking, Oct 9, 2013.
  1. Teutonicking
    Teutonicking
    Maryland
  2. concretegrazer
    concretegrazer
    Southwest MO
  3. StihlHead
    StihlHead
    The wild west
    Can you spell politics?
    From the EPA web site:
    The federal government is currently shut down. The EPA website and social media channels will not be updated until the federal government reopens. En la actualidad, el cierre del Gobierno Federal está en vigor.
  4. MasterMech
    This concerns a good part of the wood burning community so I will let it run for now.
    Remember.....
    This turns into a political pizzing match and I have to pull the plug. Keep it civil please.
  5. MasterMech
    You can talk about regulations affecting wood boilers if you keep it civil. Turn it into left vs right or similar and it gets shut down.
  6. blwncrewchief
    blwncrewchief
    NorthCentral, IN
    From the article: "An outdoor wood-fired boiler, which resembles an outhouse with a chimney". lol :p
    Teutonicking likes this.
  7. swags
    swags Moderator
    yes brilliantly written by the author
  8. Trilifter7
    Trilifter7
    Waynesville, OH
    Hahaha, funny thing is it's true :p
    jharkin likes this.
  9. Fyrebug
    Fyrebug
    The truth is OWB's can burn clean. They need to burn the same wood as you would feed a modern wood stove ie. cured dried splits. The problem arises when you give a farmer a burn chamber the size of a small apartment. Now... If I'm a farmer and worked hard all day long the last thing I want to do is chainsawing, splitting, curing etc... and if the fire chamber will accept a dozen wet round logs, a pair a rubber boots, recently deceased cow well...
    Education is in order since many users are still under the preconception these boilers are designed to burn green wood. EPA, MFG's and others (these types of forums for ex. ) should spend more time in education and demonstrating these units can perform so much better if some basic wood burning techniques were followed.
    It might be good for some OWB users on this forum to tell us how they maximize the performance of their unit and post pics of how clean they can burn.
  10. MasterMech
    You mean it wasn't designed to burn green logs?! That salesman told me that would be the best part about it, no more endless days splitting and stacking. Even built myself a loading crane so I could get them big logs in there easy like. Even saw some videos on da YouTube about how to do it right. ;)
    Education on clean burning is key. Many, many dealers and sales staff were out there misinforming the masses about how much work their boiler was going to save the customer. I work with two guys that bought big CB boilers to heat their home. One feeds it 20 cord a year (big house, 5000+ sq ft) of green, unsplit wood. The other is heating a small home and garage with an equal size boiler and insists that the slow smoldering burn from green wood is the way to go.
    Fyrebug and jharkin like this.
  11. foragefarmer
    foragefarmer
    Central, Virginia
  12. jharkin
    jharkin
    Some of it is grandstanding to push the epa process faster... Of course the court approach will probably backfire and slow it down.
    Its a good thing the new rules will include OWB. They have been exempt for too long and too many fools throwing whole trees into one. How many of have not seen one belch nasty black smoke at one time or another...
  13. foragefarmer
    foragefarmer
    Central, Virginia
    Yeah, I read a little more, the draft rules should have been out for public comment by now and they are not. So they are trying to beat the horse over the jump.
    OWB's should be regulated, as well as other appliances. But you can't regulate stupid. I have heard some crazy stuff from salesmen and owners.
    I have a problem with some of what EPA has been floating. I think we have gotten to the point where wood stove emissions should be tiered in terms of stove capacity. Even if it is just two levels. Or a fleet standard as with cars.
    Trilifter7 likes this.
  14. jharkin
    jharkin
    Agreed.The grams/hr levels should be relative to btu output.
    Teutonicking and Trilifter7 like this.
  15. Fyrebug
    Fyrebug
    This is what EPA is currently considering for furnaces, boilers and OWB. They are looking at the Canadian CSA B415.1 Standard- which itself is modeled on some European and Asian country emission standard. This standard is "emission per energy released" rather than "emission per hour". So the CSA standard is .40 g/MJ (MegaJoule). I forgot what it works out in MBTU's.
    So this standard is more 'flexible' in that the time frame of burn is not considered but rather measure by a certain amount of energy released.
    Makes sense?
  16. Locust Post
    I just get a real kick out of the folks that have the OWB and say it is better to burn green wood. How about if they mix 40% water with their gasoline to help save on the cost of fuel.
    A good friend has an OWB and he was never horrible but did not have the best seasoning practices. We have been getting him ahead the last 3 years and he is really seeing a huge benefit.....smaller fires now and using a lot less wood than just stuffing that beast full.
  17. rottiman
    What I don't understand is how burning a OWB saves $$$$$$ as opposed to other fuels. Here, where our hydro costs are high, you have to buy hydro to runs the pump and fans. My neighbor has one and last year when the hydro went down, he was screwed for heat when his generator crapped out. My woodstoves cost me nothing to run and I have a much more even level of heat on top of it. i must be missing the point. I don't see the economics.
  18. foragefarmer
    foragefarmer
    Central, Virginia
    Yes, and it makes more sense than grams per hour. Which is when the US gov. generally stumbles for one reason or another. And are they not considering it for woodstoves? The last I looked; which was this summer, they were floating 1.1? grams per hour for ALL woodstoves regardless of size.
  19. jharkin
    jharkin
    Perfect sense. In fact it should have been that way to begin with. The current system is like trying to make an 18 wheeler meet the same environmental standard as a moped. silly.
  20. Teutonicking
    Teutonicking
    Maryland
    Wow, 1.1 grams per hour, really? Even the progress hybrid wouldn't meet that standard--its rated at 1.33 g/hour.
