How do you guys block your chimneys for summer?
Discussion in 'Modern EPA Stoves and Fireplaces' started by williaty, Apr 18, 2017.
  1. williaty
    williaty
    Knox County, Ohio
    It's 80 degrees today and I'm ready to put the stove into hibernation for the summer. What do you guys do to plug/block/seal the chimney during the summer? I'm partly concerned about air sealing the chimney to reduce my air conditioning cost and also to prevent the hot, wet outside air from getting into the chimney and condensing inside the stove pipe (which will be cold due to the interior air conditioning. I've got 17' of stove pipe inside the house and only 5' of Class-A through the roof and above). I'm just as concerned about animals or insects trying to make a home inside the chimney or cap.
    What do you guys do about this?
  2. brenndatomu
    From what I have read, blocking the chimney makes moisture issues worse...I don't do a thing to mine, but I have screens on my caps. If I didn't, then I would put screens on for the summer to keep the critters out.
    Mitch Newton, Eric VW and papadave like this.
  3. Grizzly Adam
    Grizzly Adam Guest
    I close the dampers
    wildwest, UncleJoe and Eric VW like this.
  4. Backwoods Savage
    Some folks stuff insulation in the flue but we too do nothing and never have.
    As for worrying about the cold air in the chimney, that won't happen at least from inside the house. Warm goes up, cold goes down so the air conditioner should not be affected by the chimney at all.
  5. papadave
    Been thinking about putting some screen on mine, as we had 2 blackbirds get in just a couple weeks ago. The first one got in when there was still a fire going and didn't make it. The 2nd one got in when the stove was only still a bit warm, and I was able to get it out.
    I think they perch up on the rim of the pipe under the cap, get overcome by the exhaust and fall down the pipe.
    I'll be checking the baffles for damage soon.
    saskwoodburner and Eric VW like this.
  6. Eric VW
    No blocking off here, no rain cap either... Acid rain cleans up what muh brush don't get.
    :yes:
  7. chance04
    chance04
    Denton Md
    Lol
    Sent from my SM-G900V using Tapatalk
    Eric VW likes this.
  8. chance04
    chance04
    Denton Md
    In the past I haven't done anything, this year I will screen the rain cap. I'm sick and tired of digging the decomposing bodies of 4-5 birds out of my liner in the fall before I can start burning again
    Eric VW likes this.
  9. fox9988
    fox9988
    NW Arkansas 72717
    I've never blocked mine. I do get a few bluebirds out of the stove every spring.
  10. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    I set a can of "Damp Rid" in the stove and then clean out the stink bugs before I fire the stove up in the fall.
    Gark likes this.
  11. brenndatomu
    Lost BTUs... ;)
  12. Firebroad
    Firebroad
    Finksburg, Maryland
    I have an insert and have never had a problem with air conditioning running too much. I figure cold sinks, and heat rises, and my flue pipe is at an angle. If the damper is closed, the insert helps block any air.
    As far a stinkbugs are concerned, they do get in there, along with the wasps. But the wasps are gone by fall, and the stinkers are toast.
    I have a cap and a screen up top.
  13. colin.p
    colin.p
    Ottawa Canada
    I have posted this before, but in essence, all I do (as I have a through the wall chimney) is take the bottom cover off the chimney and stick a plastic Folgers coffee can lid over the 6 inch pipe leading into the house. That way anything falling into the chimney sails on through the bottom and, other than a little soot (and a cleaning of the chimney) they are none the worse for wear.
    I could have the cap replaced with a "bird discourager" type, but since my chimney cap is 500 ft in the air and I get queasy 2 foot off the ground, this is cheaper.
    FatBoy85, chance04, Ronaldo and 2 others like this.
  14. brenndatomu
    Wow, bet that drafts well! :jaw: ;) :rofl: :lol:
  15. yooperdave
    Probably has to worry about the big large silver birds with a chimney that height!! ;)
  16. FatBoy85
    FatBoy85
    Washington State
    Ok i have to ask. Are these burned birds in the stove or you flushed them out as you cleaned the stove and chimney?
  17. EnglishBob
    EnglishBob
    Upstate NY
    Nothing special, I have rain caps and screens - close the damper and doors and I'am done.
    Firebroad likes this.
  18. OhioStihl
    OhioStihl
    Southern Ohio
    Screen caps on top, foam plugs on the bottom in the house. It stops the smell in the summer months.
  19. wildwest
    No damper, I close the vent caps. Done. Pretty dry here though.
    yooperdave likes this.
  20. milleo
    milleo
    Clean your chimney, should be no smell....But I am not sure but I have not had a problem so far...
    yooperdave and OhioStihl like this.
