I Paid Too Much For A Saw To Act Like This!
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, May 3, 2017.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    My 661 is making me crazy!! Today I cut 10 rounds 16" long x 40" in diameter. I had to stop after each round was cut to break loose and move it with the tractor. This took as much as 5 to 7 minutes to do.
    Each time I came back to start the 661, I depressed the trigger and set the switch to start and the fool thing started on the first pull every time. It's never done that! I could usually get 3 starts out of it before it refused to fire.
    Every time but the last time that is.
    Following Stihl's starting procedure again, to the letter, the blasted thing would not fire. I let it cool until I could touch engine parts and feel very little or no heat. Still nothing, not even a small pop. I bet tomorrow it fires on the second or third pull.
    So what did I do different that I had not done in the past? It's a stock saw, just broken in, with no mods, except I added a pre-filter to the air filtet, like the type used on the 441. I removed that pre-filter last night because I read that it could cause the saw to bog down under load. Other than that, nothing. I've always, with maybe 4 exceptions, started the saw 'by the book'. I'm just one of those people.
    So I'm hoping it won't start tomorrow so then I can take it to the shop really 'broken'. I'm really tird of an undependable expensive saw.
  2. M2theB
    M2theB
    Central Massachusetts
    Flooded?
    Spark?
  3. Ralphie Boy
    Ralphie Boy
    The M-tronics should prevent flooding, so I can't say. I've checked for spark in the past and it looked fine, but I didn't check it this time. It's awful mot having much mechanical ability!
  4. HDRock
    I can't like that, I can't help you but, I hope it don't start tomorrow, good luck:)
    blacksmith, clemsonfor, Bert and 2 others like this.
  5. Babaganoosh
    Babaganoosh
    Jersey Shore
    That saw sucks. Let me take it off your hands. I'll send a prepaid box. Pm your address. I'll send you a poulan pro from home depot.
    Kg461, SCOTTY1848, blacksmith and 9 others like this.
  6. Shawn Curry
    Shawn Curry
    Western NY
    Did you have gas in it? :D
    Mine is probably my easiest starting saw.
  7. Shawn Curry
    Shawn Curry
    Western NY
    Get rid of that pre-filter. Usually for me if I've ran it in the last 20 mins I don't even need to choke it - just pull the cord and go. Were you choking it every time?
  8. Ralphie Boy
    Ralphie Boy
    I'm no mechanic but I'm under the impression that it doesn't have a choke like a 461. The manual says to pull the throttle and move the switch to the start position. The M-tronics 'know' what the saw needs to start. I've tried starting it without switching to the start position and it's about the same, sometimes it starts and sometimes it doesn't. Even the people at the dealership said to move the switch to start even when hot. I'm at a loss....
  9. concretegrazer
    concretegrazer
    Southwest MO
    Start position is choke on m-tronic. They've notched the choke plate to provide just enough air to idle. It can be flooded. Screenshot_2017-05-03-22-51-44.png Screenshot_2017-05-03-22-51-57.png
  10. tamarack
    tamarack
    paulina oregon
    Take it to the dealership, a 661 is like a 1200 dollar saw no exuse for it not to start. I have a 550xp thats a bit cranky on hot starts but it always will start. Could it be your 661 just needs updated software?
    Kg461, blacksmith, clemsonfor and 5 others like this.
  11. cnice_37
    cnice_37
    Vapor locked?
  12. Backwoods Savage
    For sure a saw that does not want to start can be very frustrating...and hard on the arm and shoulders. I remember when I had to put a new carb on one of our saws and it just never seemed to want to start when cold. Frustrating. Then I got out the starting fluid. Have to be careful. Not too much of that stuff. Once I got it started then it would start easy the next time.
    I say it is time for electric start on chainsaws!
    blacksmith, colin.p, thistle and 6 others like this.
  13. Bert
    Bert
    Out west.
    My 361 gives me fits, I think I have it adjusted right and the next time I use it:mad:(not)! I think I'd get with someone that has a 661 and see if maybe it's something you might be doing wrong (just a thought)...........:whistle:
  14. Ralphie Boy
    Ralphie Boy
    I talked to the service manager at the closest Stihl dealer today. He said he had heard of hot restart problems but has never had a saw in with that problem, "But then we don't see many saws that big here." Really?
    He said with M-tronic saws the only way to get at the problem is bring the saw in and plug it into the computer. Makes perfect sense to me. He also verified that I am using the correct starting sequence.
  15. Redfin
    Redfin
    central Pa
    I have used a few 661s that even after cooling down would not need to move the switch to start.
    Have you tried leaving it on run?
  16. Ralphie Boy
    Ralphie Boy
    Yep and I get tbe same results, a couple of 1 pull starts then nothing. Gotta be electrical or software.
  17. Redfin
    Redfin
    central Pa
    Im betting its the solenoid on the carb.
    Kg461, Hinerman, blacksmith and 8 others like this.
  18. MasterMech
    It could indeed be the carb solenoid. I would think there would be some running issues as well however if it was indeed the solenoid. I highly doubt that it's a software issue, as the same software is in thousands of saws that work flawlessly. The microswitch mentioned in the troubleshooting charts would be highly suspect as this is -only- an intermittent starting issue, and the OP has indicated that once running, the saw operates normally.
  19. Ralphie Boy
    Ralphie Boy
    I'm sure it's some stupid simple.
  20. ironpony
    ironpony
    Mid Ohio
    Chainsaw......updated software.........yup they screwed up another mechanical device
