"Drill Doctor"- anyone tried one?
Discussion in 'The DIY Room' started by Beetle-Kill, Feb 16, 2014.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Every time I head back home from Nebraska, my Dad tries to load me up with "things". Whatever he's ready to get rid of, suddenly I need these things. The latest is the Drill Doctor sharpening unit.
    So, tonight, I tried it.
    It's the XP2 model and it seems to give a decent edge. So..
    Has anyone used one? Any tips or tricks to getting the best grind?
    Thanks, JB
  2. nate
    nate Banned
    Palmer, AK
    Ive had one for years. It kinda works, but nothing close to the same as a factory edge or hand sharpening if you know how.
  3. Beetle-Kill
    Beetle-Kill
    Thanks Nate. Yeah, looks like the relief isn't angled enough but I only tried a few bits. Can this thing be adjusted?
  4. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    I have not had any luck with those, but I learned to hand sharpen, and it's definitely a skill worth learning.
    Fifelaker likes this.
  5. nate
    nate Banned
    Palmer, AK
    Mine came with a VCR tape that shows how to work it. I went to check and mine is the 750x model, which I think is a bit older. Does bits from 1/16" to 1" I believe.
    It works ok enough that I've kept it. It "roughs in" the bit ok, and if I go back and fix it by hand its not bad.
    The main issue I've had is it sharpens the point at the wrong angle and doesn't remove enough material behind the cutting edge.
    www.machinistblog.com/review-drill-doctor-750/
    Beetle-Kill likes this.
  6. nate
    nate Banned
    Palmer, AK
    Whoa, not sure why it posted like that! It's not allowing me to delete the first 2.
  7. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    Easy Nate, Easy!!!!
  8. Beetle-Kill
    Beetle-Kill
    Nate,....Jeeeez, heard you the first time. :D JK
  9. smoke show
    smoke show
    Pittsfield, Wi
    quoted from this link provided above. www.machinistblog.com/review-drill-doctor-750/
  10. nate
    nate Banned
    Palmer, AK
    Could be, I wasn't going to dig it back out to check.
  11. ironpony
    ironpony
    Mid Ohio
    if you need to sharpen bits that often;
    1) you need to get better quality bits or
    2) you need to learn to drill at the proper speed / pressure
    3) correct cutting fluid for the material being drilled
    :emb:
  12. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I've got one at work and it's a piece of junk that literally has sat since I have run the department. It's far easier and sharper to use a bench grinder and a bit holder...
  13. chris
    As said relief isn't quite enough on the non industrial units, the split point function is handy. got one of the real early models . mostly use it for splitting points on small drills and the carbide tip drills for masonry work. I have other drill grinders which do a better job ( industrial units) and yes I can do free hand as well. Their industrial units seem to be ok ( 2000 series I think) leastwise I know a couple shops with them and haven't heard any major complaints. Course they are not 50k machines either. I sharpen commercial so the bits I get are really trashed ,for those these units will not work as a lot of times I have cut them off and start from scratch.
    raybonz likes this.
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    Used to work for a guy that was a hand sharpener at Morse twist drill.. He showed me how to sharpen using a vertical band sander or a disk sander.. Grinders work but are harder to work with.. Easy once you get the technique down.. Understanding the geometry helps much too.. I can show someone how to do it but not explain in text..
    Pallet Pete likes this.
  15. Beetle-Kill
    Beetle-Kill
    Ok, I said screw it and ran 75-100 bits through it. And then... started punching holes in some 1-1/2" Cold rolled round. I had 4 pieces @ 4" I had to open up to 5/8"+ ID. #2 center drill for a pilot, then 5 stepped sizes until I hit .625. I was not gentle nor was I slow. I did not have the lathe in back-gear, I went Med. high and slower on the feed. And they cut fine. Not smooth, but they made a hole. I used a straight flute reamer to clean up the holes, but it really didn't do anything. All-n-all, for rough boring, it worked fine for sharpening. JB
    Oh yeah, I never had to sharpen any bit I used during this process, so 16" of CRR and they're still Ok.
