Nice Find....I hope
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Apr 15, 2017.
  1. M2theB
    M2theB
    Central Massachusetts
    IMG_0434.JPG IMG_0435.JPG On the way to the store I passed a chair and what looked like a saw below it at the end of a driveway. I turned around and got back to the spot and then saw the sign in the chair FREE.
    Back at the house i gassed it up and bar oil. 3 pulls and it turned over. On and off the choke and fired up. Real high rev and when I goosed it to calm it down it bogged under the trigger and died. Started right up again though. Similar thing.
    I'm going to mess with high and low tuning.
    Feel free to give me your thoughts.
    I'll report back on progress
  2. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    You got that big azz saw for free?!!?:faint:
    Hammy, Eric VW, Chvymn99 and 3 others like this.
  3. papadave
    Nice find, but...........you suck. :rofl: :lol:
    Man, some guys have all the luck.
  4. Horkn
    That was a score.
    It's probably a carb or fuel line simple issue.
  5. MasterMech
    Make sure the muffler screws are tight on those.
    Hammy, Eric VW, Horkn and 3 others like this.
  6. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Take the carb off spray it out with carb cleaner. Throw a new plug and air filter on.
    30 Clip Magazine On My Ghost Gun
    Hammy, Eric VW, Horkn and 2 others like this.
  7. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Another thing is start with fresh gas.
    Hammy, Eric VW, Horkn and 1 other person like this.
  8. M2theB
    M2theB
    Tried to share a video but it must have been too big.
    Pulled and cleaned the filter and spark arrestor. Put Husq 50 mix in a can in. Tuned the idle first and got it to idle ok. A few iterations on the high and low settings. I got it to a point that just before it would die, I could back off on the trigger and keep it going. Kept doing that for a few minutes until I had it screaming, drop to idle and back up. I'd shut her off and quick start right after and right to idle. It's still a little dodgey coming out of the blocks, but that might be a fine tune. I think it just had bad fuel in it for too long. And yes, one of the muffler bolts is spinning. And it leaks bar oil pretty good.
  9. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Nice...
    Hammy, Eric VW and Horkn like this.
  10. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Where is it leaking bar oil?
  11. M2theB
    M2theB
    Out of the oiler area, under the bar hold down plate
  12. Chvymn99
    Nice find....:thumbs:...
  13. bogydave
    !!!!!!!!!!!Nice SCORE !!!!!!!
    :thumbs:
  14. M2theB
    M2theB
    It needs more love for sure. Or better cleaning. After it sits for 10 minutes or so and cools down it goes back to hard to getting it up to full speed. I have to baby it past the stall point. But after I do, it screams at the top, goes back to a nice idle and back to the top without issue.
    The one thing I did notice that all look into is that it has "Air Injection" on the sticker. I've never seen that before.
  15. MasterMech
    Air injection, while cool tech and all, is fancy marketing wank for pre-cleaning the air before it sees the actual air filter.
    Hammy, cnice_37, Eric VW and 2 others like this.
  16. M2theB
    M2theB
    So it is not some gizmo that could have gone south and be part of its problem?
  17. MasterMech
    Not a single moving part. ;)
  18. MasterMech
    If I remember right, these had a plastic clamp on the carb boot that was problematic?
    cus_deluxe, Mag Craft, Hammy and 7 others like this.
  19. Horkn
    If that's the case, a simple metal hose clamp should fix it. No?
    Hammy and Eric VW like this.
  20. MasterMech
    Better yet, Husky puts out a metal clamp to replace it with but I have no idea what the part number is. Ask anybody with a 346XP. Browse 346XP or 345/350 build threads it shouldn't take long to stumble across it.
    Standard worm drive clamps are horrendous at sealing. The proper clamp works just a tad differently.
    Hammy, Warped5 and Eric VW like this.
