Recommendations for pet safe weed killer
Discussion in 'Everything Else (off topic)' started by Screwloose, Apr 14, 2017.
  1. Screwloose
    Hello everyone. Can someone please recommend a dog safe lawn weed killer ? In the front yard I use Weed B Gone max by Ortho. It works well enough but in the back yard our dog will nibble on the grass so I don't use anything. Just looking for alternatives. Any suggestions ?
  2. bogydave
    Distilled vinegar works on many weeds
    Works on slugs too
  3. papadave
    Like bogy said...........^^^
    Chvymn99 and Screwloose like this.
  4. Puppy Daddy
    Puppy Daddy
    Illinois
    I use a weed dragon, no chemicals and I get to play with fire. I made a shield out of some old soffit to keep the wife's flowers from damage. You don't have to burn the weeds down to the ground just hot enough to burst the plant cells.
    Screwloose, savemoney and eatonpcat like this.
  5. Loon
    Loon
    North of the border
    Chlorine doesn't hang around long at all and kills everything.
  6. RCBS
  7. brenndatomu
    This one works pretty good...may not get the really tough ones in one round, but anything non-toxic is probably the same
  8. lukem
    Plain old hot water kills weeds if you are spot treating.
    Screwloose likes this.
  9. savemoney
    That mix does work, but it isn't like something you can put down and let it kill the weeds but leave the grass alone. To me, nothing is worth risking poisoning the pets. To that end, I selectively spray with your mixture, and the rest can just grow. Better a weed lawn than a sick dog.
  10. concretegrazer
    concretegrazer
    Southwest MO
  11. Screwloose
    I do use the vinegar soap salt mix and a burner for total veggitation killing. But I was looking for something to spray on the whole yard. They all say "pet safe when dry" but ours like to nibble so dry doesn't matter.
    Chvymn99 likes this.
  12. Screwloose
    Got one, she won't do it.
  13. papadave
  14. Screwloose
    I couldn't resist, sorry.
  15. brenndatomu
    That line or something similar went through my mind but I couldn't figure out how to word it without potentially stepping "over the line" so I decided to leave it alone. ;) :whistle:
  16. brenndatomu
    I just did a little lookin...research sugar weed control, see what you think...sounds like it may have possibility's for you...
  17. Screwloose
    Thanks, very interesting. I'm going to experiment today. It also mentioned sawdust as a carbon source. Is this why my cutting area stays weed free ?
    FHC brand organic pet safe weed control chips........
    brenndatomu, Chvymn99 and papadave like this.
  18. concretegrazer
    concretegrazer
    Southwest MO
    Might need to pay more.:makeitrain"
    I'm not buying that. Sugar will bind the nitrogen starving the weeds. But that starves the grass as well. Causing another list of problems.
    The best thing organically is to think long term. Build up the grass to provide a canopy as to prevent weed seeds from germinating.
    Screwloose, Chvymn99 and papadave like this.
  19. papadave
    I'm starting to use wood shavings/sawdust from the shop out in the garden to control weeds in the walkways and not planted areas.
    We also use lots of straw in a think layer. Prolly wouldn't apply in your situation.
    Screwloose and Chvymn99 like this.
  20. Chvymn99
    I use vinegar, Clorox, and some soap for my areas around my chickens areas...
    Screwloose and papadave like this.
