MC% of wood: 51% & 104% is the same
Discussion in 'The Wood Pile' started by bogydave, Apr 4, 2017.
  1. bogydave
  2. bogydave
    Wonder how a MM % is calculated. ?
    DC electrical Resistance inside a 1" portion of the wood fibers ?
    Any salinity of the moisture inside the wood used &/or wood type ?
    (Thought like this are symptoms of "Cabin Fever" )
    LongShot, papadave and Ralphie Boy like this.
  3. Backwoods Savage
    My MM is 3 years in the stack! % will always be less than 20% if it is stacked and top covered right.
    milleo, LongShot, FatBoy85 and 3 others like this.
  4. bogydave
    Same here,
    The 3 year plan works !
    Burns good too ;)
  5. Jon1270
    Jon1270
    Pittsburgh, PA
    Pretty much. Moisture meters don't measure moisture at all; they measure electrical properties that correlate reasonably well to moisture content. All the relatively affordable moisture meters are just glorified ohmmeters. Below about 6% MC the resistance of wood is so high, and above 28% the resistance is so low, that electronic meters can't make heads or tails of the situation, but inside that range they do reasonably well, give or take a couple percent for variations of temperature and species.
  6. CTYank
    CTYank
    CT Panhandle
    Yup, given such time out of rain/snow to approach EMC (equilibrium moisture content) with local atmosphere, MC of wood stacked outdoors here will settle at 10-12%, dry basis. So goes the theory, and the way it happens. Stacked near the stove for a while, it won't budge a MM. :dancer:
    Backwoods Savage, Jon1270 and Sean like this.
  7. DaveGunter
    DaveGunter
    So what's the answer? MMs approximate a measurement that is green basis or oven dry basis?
  8. Jon1270
    Jon1270
    Pittsburgh, PA
    Oven dry. As noted up at the top, oven dry basis is the standard for lumber, plywood and similar products, and those are the products that moisture meters are primarily designed and used for. Firewood is kind of a niche application.
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    It's worth noting that the difference in the numbers gets smaller as moisture content gets lower. Bogydave's example uses very wet wood, so the difference is dramatic, but 15% dry basis is the same as 13% green basis. If you're dealing with kiln-dried hardwoods meant for furniture, trim, etc. then you might be looking at 7% dry basis vs. 6.5% green basis. It becomes an almost meaningless distinction.
  10. Paul bunion
    Paul bunion
    Except in the case of the EPA stove tests. The test specifications are done on a wet basis. 20% wet = 25% dry.
  11. Jon1270
    Jon1270
    Pittsburgh, PA
    Interesting. I know a fair bit about moisture meters, but not so much about stove testing standards.
  12. Paul bunion
    Paul bunion
    The standard for emission tests is to burn cribs of doug fir lumber at between 16-20% wet. Far from everyday real world use.
