Attn mechanics....
Discussion in 'Everything Else (off topic)' started by Well Seasoned, Apr 4, 2017.
  1. Well Seasoned
    Dawn's car had a decent pull to the left. Switched out front brakes, a rotor, caliper, and had it aligned today.
    We still have a slight pull to the left. Tires are pretty close on air pressure, what else am i missing? Gear box? Its a '99 Subaru impreza outback. Would like it safe since son will be driving soon.
    blacksmith and Backwoods Savage like this.
  2. Redneck
    Redneck
    Burton mi
    Does the car shake or pull at all speeds or at a specific speed
  3. bocefus78
    bocefus78
    Did the guy who did the alignment inspect the ball joints, tie rod ends, idler arm, and other components or did he just align it and take your $? Maybe he forgot to recenter the steering wheel?
    How good is your air gauge? A couple lbs can make a difference.
    Could also be wind or crown in the road.
  4. Well Seasoned
    Doesn't shake, the steering wheel did prior to having the work done. Pulls harder at 50mph+
    This was just a tire place who recommended an alignment while i had new snow tires put on, i didn't though. They only "align" per the paperwork i got "after" the job was done, no added jobs or modifications. (how convenient :loco: :crazy:) I will add Dawn hit a nasty pot hole and blew the side wall a month and a half ago. We got a new studded tire, balanced, etc. Small dent in rim, but holding air.
  5. Redneck
    Redneck
    Burton mi
    Pull the dented rim off and put on the spare see if problem goes away. If so need new rim.
    Had similar issues last year had to replace two rims. When i bent the third on gave up and replaced the factory rims with steel rims and hub caps have not bent a rim or had issues with front end like i did with factory rims
  6. Well Seasoned
    Ill know for sure in a few weeks when i swap the summer tires and rims back on. Unfortunately the spare tire is a little doughnut.
  7. bocefus78
    bocefus78
    Rim is probably wasted but the tireshop should have caught that. Keywords.... Should have. If its found to be bad, I would also examine any other wheels that hit the same pothole for cracks, bends, etc.
    If the summer wheels still pull left, it's time to get the front end looked at.
    If you have a floor jack, Jack up 1 front side at a time and see if there is play by shaking the tire. Place hands at 3 and 9 o'clock and move back and forth.
    Then do same with hands at 12 and 6.
    Make notes of which direction anything moves and where your hands were placed when it moved and report back.
  8. Well Seasoned
    Good info.... thx! :yes:
  9. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    You may have a bad brake hose, I thought I had a bad caliper on my plow truck, it ended up being a collapsed brake hose.
  10. Well Seasoned
    I need to find a dry place to look over everything. Mud fest here!
  11. Canadian border VT
    well if ya loose 3 feet of snow like I did.. and 3 days of 40 and rain yup the 5th season...MUD season!
  12. Well Seasoned
    Yup, i feel like i need to wear snow shoes outside, cept there's no snow :D
  13. Redneck
    Redneck
    Burton mi
    Be careful with the car pulling like that it will definitely add wear to your tires and front suspension. A couple of weeks can and will add a lot of stress to your front end. Causing unneeded wear and safety issues if the rim is bent or cracked and it finally breaks apart or causes the tire to go flat. I had a tire blow out on the drivers front a couple of years ago i rolled the truck over several times after i lost control of all steering when it blew.
    Not trying to sound all doom and gloom but just be very careful.
  14. RCBS
    Wheel bearing?
  15. Gasifier
    Remove the unseasoned Oak firewood you forgot in the back on the left side and report back!:picard:
  16. MightyWhitey
    MightyWhitey
    Winter air or Summer air in the tires??
  17. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    swap the front wheels side to side, differential wear can make a difference in subies...
  18. 94BULLITT
    94BULLITT
    Frederick County, VA
    Is it pulling under braking or all the time?
    Sent from my SPH-L710 using Tapatalk
    Well Seasoned likes this.
  19. Well Seasoned
    Fall air :)
    Ill try this over the weekend! Thx:)
    All the time over 50mph. Since having the work done and the alignment, the pull is just slight now.
  20. Eric VW
    Replace the car with a '72 VW Beetle (not the Super Beetle)....:whistle:
    :thumbs:
    blacksmith likes this.
