Any adjustment on pellet consumption in maintenance flame mode of Harmon?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Orson_Yancey, Mar 27, 2017.
  1. Lousyweather
    Lousyweather
    yea.....I am not convinced they work
    ivanhoe likes this.
  2. Harman Lover 007
    Harman Lover 007
    Eastern Mass
    Perfectly stated LW. I did the weldment job myself on my Invincible. Big job. Being a manual lite stove I got 16 years out of the auger tube before the hole opened up.
  3. Lousyweather
    Lousyweather
    that's pretty good....year 18 on mine, so far, so good
  4. don2222
    don2222
    Salem NH
    Hello
    In Stove mode,
    If there is a 6 RPM motor then how about changing it to a 4 RPM motor?
    What are the pros and cons on that???
  5. Lousyweather
    Lousyweather
    well, all feed would still be calculated based upon an assumed 6 rpm, and depending upon the feed rate setting, you'd likely still burn deep into the throat of the burnpot, depending upon heat demand......not sure why youd want to do this.
    ivanhoe likes this.
  6. Luneyburg
    Luneyburg
    Hills of Central Mass
    OK shutting down the stove to install room air sensor after reading this thread and warm weather ahead.Good informative thread and made a believer out of me.
    Thanks
    ivanhoe likes this.
  7. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Do you want me to explain exactingly how they work? I thought this was a family safe site? The Mods will get on my case.
    jtakeman, Lousyweather and ivanhoe like this.
  8. don2222
    don2222
    Salem NH
    If the stove was set to constant burn or stove mode and the auger motor was 4 RPMs instead of RPMs then the # of pellets fed in one auger rotation would be less and reduce thus reducing the heat output like the OP wanted?
    Also if the control panel is older then a new control panel may help. There are changes to the heat algorithm that we never hear about.
    Maybe the best way to reduce the heat is to put in a P61a for the shoulder season. I have 2 - P61a-2 stoves so if I want to increase the heat on the cold days, I just flip on the other stove. :)
    Orson_Yancey likes this.
  9. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Fine for the feed not so good for the combustion air side depending.
    ivanhoe likes this.
  10. Lousyweather
    Lousyweather
    or, if in STOVE/CONSTANT burn mode, simply turn it down?
    offspec feed motor installed = voided warranty
    ivanhoe likes this.
  11. Lousyweather
    Lousyweather
    alpha blocker blahblahblah
    ivanhoe and jtakeman like this.
  12. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Don't forget its urine pressurization and poop softening abilities.
    ivanhoe, Lousyweather and jtakeman like this.
  13. Harman Lover 007
    Harman Lover 007
    Eastern Mass
    TMI
  14. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Well, I did warn him.
  15. jtakeman
    :whistle:
    :binoculars:
    ivanhoe and SmokeyTheBear like this.
  16. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    You rang?
    ivanhoe, bogieb and jtakeman like this.
  17. Lousyweather
    Lousyweather
    I see no difference
    ivanhoe likes this.
  18. gbreda
    gbreda
    NH
    I have had that happen once or twice in the 8 years I have been burning. Some kind of hiccup that had me scratching my head and questioning the igniter but it hasnt repeated.
    Only the Hermoan users are perfect :whistle:
    jtakeman, will711, Tullytown and 2 others like this.
  19. jtakeman
    Ha! Lemme chat with your boss, Bet she can supply us with a few imperfections!! :whistle:
    :zip:
    :doh:
    gbreda likes this.
  20. gbreda
    gbreda
    NH
    Bet she could come up with at least one but unlikely any more than that :zip:
    jtakeman likes this.
