Anyone do groundhog hunting?
Discussion in 'Hobbies and Interests' started by Marshel54, Mar 26, 2017.
  1. Marshel54
    Marshel54
    I have several groundhogs that I have to eliminate around here. Only seem to see them when I don't have the rifle with me. Any suggestions of time of day and weather conditions would be helpful. Should of got the message to them that they are unwelcome a couple of years ago, but didn't have time. Retired now so I have plenty of time to send them a message.
  2. blacksmith
    blacksmith
    central Pa
    The best time I've found to hunt whistle pigs is in the morning till around 10 to 10:30 and the evening from about 5 to dark on sunny days. On more over cast cooler days you can see them most any time of the day.
  3. TurboDiesel
    You can catch a groundhog out just about any time of the day.
    What distance is it away?
    What caliber you using?
    How skittish is it?
  4. brenndatomu
  5. HDRock
    X2
    Go out n mow the grass about 10am and wait .
  6. Casper
    Casper
    I've become a huge fan of the 17HMR, at least where I see them. The round drops them in their tracks. The added benefit is the round is so light it doesn't carry far, especially if it ricochets after hitting the ground.
  7. Chvymn99
    I've got a pellet gun for close encounters or a .22 for longer range standoff... I'll sit in my garage and wait them out if I know they are eating my clover...:D... the traps are good, but just make sure no pets are around to get caught in them...
  8. HDRock
    Caught a cat in live trap when trappin coon with cat food ,no harm , let him out in the morning
  9. J. Dirt
    J. Dirt
    We've got a bunch at our place in PA and we always make a point to go run the bush hog around the few known holes when we get there if the fields high.:yes: Usually seems first and last few hours of the day but we've also got a pear tree about 50yards from the front door of the camp and the two holes there are usually all day action. At home or within 50yards the .22, .17 hmr or .30carbine are fun but usually it's the deer rifles 30/06 or .308 since some shots stretch out past 350 yards
  10. TurboDiesel
    I've shot a few hundred hogs with the .270. It doesn't miss out to 300 yds.
    I've even got one at 425. That's some fun hunting right there!
  11. Marshel54
    Marshel54
    Distance would be with in 50 yards and I will be using a .17HMR
    Thanks all. Just didn't know weather and time of day to hunt. There seems to be no rhyme nor reason when I see them. I will have to get the rifle and lawn chair out one of these evening.
    FatBoy85, Bert, Eric VW and 5 others like this.
  12. brenndatomu
    Most people that I know that "hunt" 'em go out an hour or two before dark...anytime after the heat of the day is when I see the lil buggers waddling around the most.
  13. Will C
    Will C
    New York
    I haven't much hunting lately, but I always did it in the evning after work. They seem to have changed their habitat around here-I used to watch farm fields and shoot them-now it seems like I see most close to houses and buildings. I think I shot the last 5 between 15-30 yards with either a .22 or a handgun. It is far different than when I shot them @ 200, 300 yards and more with a .222, .22-250, or .243.
  14. Casper
    Casper
    Fresh cut hay fields or before soybeans get too high. Like Brennan says, evening is when we had the lost luck. Usually rode around the hay fields in the back of the truck after the last load of hay was in the mow.
    Killed 15-20 a year that way. Who knows how many wagon spindles were saved.
  15. XXL
    XXL
    Ontario, Canada
    It's been years since I hunted them but we found them to be inquisitive little critters. When they got shy and skittish we found they would pop their heads up to investigate a strange noise so we would use whistles and such to get their attention.
    I few times I would ride around the fields on my motorcycle and when I spotted one diving down a hole, I would put the bike in neutral, lay it down on it's side, get into the prone position using the bike as a bench rest. I would then reach up and twist the throttle revving the bike up. They couldn't resist the urge to stick their heads up to see what was going on :whistle:
  16. TurboDiesel
    They must THINK they're hiding when they're just peeking out of a hole.
    :binoculars:that's all I need to see...:cool:
  17. J. Dirt
    J. Dirt
    Speaking of wagon spindles.... I watched my great gramp snap the front end off his narrow front Farmall 230 in a chuck hole it just swallowed both front tires a loud bang and there it sat on the loader frame
    Eric VW and blacksmith like this.
  18. clay shooter
    clay shooter
    ENGLAND
    iv shot some when on the farm in michigan.we dont have in england.
    Bert, blacksmith, Eric VW and 2 others like this.
  19. Casper
    Casper
    Took out two this morning. Remington 700 with bull barrel shooting Fiocchi 223 loaded Hornady Vmax 40gr. @ 3300/fps. Tends to take care of them out at 300yds.
    Bert, blacksmith, brenndatomu and 5 others like this.
  20. clay shooter
    clay shooter
    ENGLAND
    can you shoot them all year round over there.
    Bert, HDRock and Chvymn99 like this.
