Moisture Meter
Discussion in 'The Wood Pile' started by MikeyB, Mar 25, 2017.
  1. MikeyB
    MikeyB
    Long Island NY
    hey guys, newbie here. Not sure if this has been discussed before but I recently order a Sthil firewood moisture meter and was wondering if you should test the split log in the middle going with or against the grain for moisture content?
    Appreciate any feedback, thanks guys.
  2. papadave
    My understanding (which could very well be inaccurate) is the pins should be inline with the grain direction.
    You gonna' split those rounds in your avatar?:axe:
    Oops, welcome aboard! Nic to see another new face....so to speak.:thumbs:
  3. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Fresh split at room temperature. What's more important than with or against the grain is to make sure you get the probes in deeply.
  4. MikeyB
    MikeyB
    Long Island NY
    Thank you PapaDave, yes those rounds are split and stacked. Appreciate the welcome as well. I'm new to this Fire wood world and this looks like a great place to learn.
    Handsonautotech, Sean, HDRock and 5 others like this.
  5. papadave
    Just so you know, we'll need a detailed report of your setup......with applicable pictures. :D:picard:
    Kind of a rite of passage. :dex: Mostly, it's because we like pics.
  6. MikeyB
    MikeyB
    Long Island NY
    Just started a fire and relaxing with the family on this fine Saturday evening.
    Handsonautotech, Sean, HDRock and 8 others like this.
  7. papadave
  8. Horkn
    This^^^
    Moisture meters are calibrated for 70° temps. I've seen no discernable difference between readings with or against the grain, or on an end vs split given the splits and cuts were made at the same time.
    Welcome to FHC MikeyB !
  9. MikeyB
    MikeyB
    Long Island NY
    Thank you Sir.
    Handsonautotech, Eric VW and Horkn like this.
  10. Eric VW
    Welcome aboard MikeyB from a former Long Islander:handshake:
    Do you plan on just using the fireplace for ambience, or will you eventually install a stove or insert?
  11. MikeyB
    MikeyB
    Long Island NY
    Thanks Eric, where were you on LI? The fireplace is used for ambience for now, currently heating that zone with forced hot water heat, but I have to lower that zone down when using the fireplace due to it warming the floor up a couple of degrees. Love that radiant feeling off the fireplace.
  12. Eric VW
    I grew up in Wading River, went to Shoreham Wading River schools...
    Where are you?
    Horkn likes this.
  13. MikeyB
    MikeyB
    Long Island NY
    In Massapequa Park, My wife and I have been here going on 12 years. Originally from Elmhurst Queens NY...
    Horkn and Eric VW like this.
  14. yooperdave
    Yeah, pics. So much easier to read pics than letters and words formed into sentences.....always jumbled up and all.
  15. Horkn
    Isn't that where Kevin James' character on "Kevin can wait" is based? Someone on that show always has a "massapequa" shirt on.
    Eric VW likes this.
  16. Canadian border VT
    Welcome MikeyB my meter says room temperature ... so on my fast drYing wood, birch, soft maple I single row stacked til I got ahead.. so for example red maple 9 moths stacked I check it both end and middle take an average.. per instructions on my meter.. an example I got would be readings would be 22 in middle 18 on pointed east end of split and 17 on other.. (stacks run north to south for most sun) that piece of wood averages 19% or ready to burn... this is a lot checking... so they preach 3 year rule here... meaning get 3 years ahead in cut split stacking (CSS) cause the slowest drying wood namely oak will be good and dry by then....
    MikeyB, HDRock, Eric VW and 2 others like this.
  17. papadave
    Finally.
    Someone else who gets it. :rofl: :lol:
  18. HDRock
    X2
    I've seen no difference with or against the grain, this too, end vs split given the splits and cuts were made at the same time.
    Checking the outside of a chunk won't tell you anything , split it and check it then n there smack in the middle, to know what the moister content is inside the wood.
    Welcome to da club MikeyB :drunk:
    Ashwatcher, MikeyB, Sean and 2 others like this.
  19. Sean
    Sean
    Welcome to FHC MikeyB as with what HDRock says Ive never seen any difference between with or against the grain but I switch back and forth just for amusement for just such conversations. You are supposed to go with the grain but we are just talking firewood here so it doesnt matter much at all. Room Temperature and in the middle of a freshly split round is key for checking mc.
    Horkn, MikeyB, Eric VW and 1 other person like this.
  20. MikeyB
    MikeyB
    Long Island NY
    Thanks guys, I appreciate all the info. And I'll be sure to post more pics as I go along.
    Horkn, HDRock, Eric VW and 1 other person like this.
