Riding Mower Problem
Discussion in 'The DIY Room' started by ReelFaster, Mar 21, 2017.
  1. ReelFaster
    ReelFaster
    S.Jersey
    Fired up the mower this evening, let it warm up a bit and starting driving slowly. After riding 10-15 seconds the mower dropped out of gear and stopped. It will not engage at all now cannot go forward or backwards. Also the blades will also not engage either very very stiff/difficult to try and engage them. It's a Craftsman Model LT 2000. Engine runs great! Am not the best mechanic but any advice or simple things to look for or try would be greatly appreciated. Its funny because I just put a thread out about buying a trailer or truck. Fired up the mower tonight to bring to the garage to mount a ball hitch on it to drag the trailer I want to buy around back. Now I need the dam trailer to probably have mower repaired, pretty ironic!
    Canadian border VT and papadave like this.
  2. Unhdsm
    Unhdsm
    Bradford, Vermont
    Are the drive and pto belts still on there and routed correctly?
  3. ReelFaster
    ReelFaster
    S.Jersey
    Gonna push it up into the garage and get it on jacks to see underneath. Also going to go back over the area it slipped out of gear make sure nothing isn't laying there that might leave a clue!
  4. Highbeam
    Highbeam
    Both blades and drive down at the same time but engine running just screams of a belt issue.
  5. TBONE
    TBONE
    Carey, Ohio
    Does it have a hydro trans axle? Those are know to go bad as did the one on my dad's. Also check the drive belt.
  6. Canadian border VT
    cannot add anything else to help.. sorry but as I still got a foot of snow and 8 degrees I got to fix snow blowers not lawn mowers!
  7. bocefus78
    bocefus78
    If it's belt drive, you may have broken the main aluminum pulley that spins the transaxle and deck belts. Ive seen that more than once.
  8. HDRock
    Belt popped off, belt broke, pulley seized up, idler pulley pivot point seized up, mower bearing seized and burned the belt, look it over, push in clutch see if everything is functioning as it should
  9. ReelFaster
    ReelFaster
    S.Jersey
    Thanks fellas gonna get it up jacks and see what's happening under there. Will report back in!!
    TBONE and Canadian border VT like this.
  10. ReelFaster
    ReelFaster
    S.Jersey
    So I finally got her jacked up to take a look underneath and low and behold this is what I found. As mentioned by someone the issue screamed of a belt issue. Problem is I haven't a clue how to repair, lol! Trying to go through manual now and see what it all should look like under there but again am not a good mechanic! IMG_20170327_181026747.jpg IMG_20170327_183707048.jpg
  11. chris
    looks like idler bearing froze rest of damage caused by friction of belt on composite sheave. Doesn't look like a difficult repair. New belt and sheave.
    ReelFaster likes this.
  12. ReelFaster
    ReelFaster
    S.Jersey
    Thanks Chris! Trying to get a visual of it so I an follow, not sure where the belt is suppose to go. Also do you think this would affect the blade level? That seems very difficult to engage and LN when I tried to engage it seemed to want to cut the engine out....!
  13. TBONE
    TBONE
    Carey, Ohio
    I'd guess something similar to this for the belt routing.
    Chvymn99 and ReelFaster like this.
  14. HDRock
  15. chris
    Frozen bearing put excess drag on system - stall eng.
  16. ReelFaster
    ReelFaster
    S.Jersey
    Thanks Chris, she's in the shop as of this morning..........little over my head, hopefully i'll learn a thing or two going forward.
    HDRock and eatonpcat like this.
