Ott accu-stick review
Discussion in 'Chainsaws and Power Equipment' started by Barcroftb, Mar 20, 2017.
  1. Barcroftb
    Barcroftb
    The Mitten
    Ott Accu-Stick
    I've had my eye on one of these for awhile now and finally decided to take the plunge. At 30 bucks it is a little more expensive than making one myself, but I felt the adjustable length and aluminum construction was worth it
    The anodized aluminum will make it easier to spot if dropped in the woods.
    It has a high-vis reflective end
    Ott recommended placing the accu-stick in the valley of the felling spikes like this:
    But after using it awhile tonight I found I liked it closer to the tip of the bar. Having it placed out there I could quickly mark the entire tree, and then put the accu-stick in my pocket and buck the tree up.
    What I like so far:
    Light weight but sturdy
    Super strong rare earth magnet
    Easily adjustable length from 14"-26"
    Made in the USA
    So far I haven't found anything I dislike about it, and will likely recommend it to friends and family.
  2. Grizzly Adam
    Grizzly Adam Guest
    Fyi, we have a ratings and reviews forum.
    raybonz, savemoney, Chvymn99 and 5 others like this.
  3. HDRock
    I like that one. Best one out of all the commercial ones I have seen
    I like the fact that it's aluminum and very light and magnet mount
    I like the magnet mount on the one I made because I can put it on either side or anywhere on the bar I like, mine is adjustable about 4 inches in length but I have to have the small allen wrench to do it.
    Most of the time that's what I do is, Mark the log take it off then cut it up,, it works ok to leave it on also
    raybonz, savemoney, Chvymn99 and 4 others like this.
  4. Barcroftb
    Barcroftb
    The Mitten
    I really liked that I could put it on either side of the bar too.
    Yeah I started out using it with it on there but I was cutting small stuff so it seemed to work better with it at the tip just marking then taking it off. I can see it working good on bigger stuff just leaving it on there.
  5. HDRock
    I haven't seen any commercial ones that I would really buy, too heavy, too flimsy, wrong type of mounting, but I would spend 30 bucks on this one.
    What's the diameter of that magnet?
  6. Handsonautotech
    Handsonautotech
    Big Elk Meadows Lyons CO
    Just when I thought I had run out of things to spend money on.
    raybonz, LongShot, savemoney and 9 others like this.
  7. CtRider
    CtRider
    I just use my bar - turn saw sideways, pick spot at the end of the bar and cut there.
    M2theB, savemoney, XXL and 5 others like this.
  8. Eric VW
    Excellent Barcroftb :thumbs:
    Really dresses up that already sweet looking Dollie :yes:
  9. CoachSchaller
    CoachSchaller
    Southeast Michigan
    nice idea, thanks for the review
    raybonz, savemoney, Chvymn99 and 3 others like this.
  10. brenndatomu
    Now there's a line ya don't here many guys use in a days time! :whistle: ;) :rofl: :lol:
    I tried to make one of these markers using a magnetic trailer hitch alignment device (for backing up to the trailer by yourself) it worked OK, but the magnet was not strong enough to hold it in place once you started cutting...'course maybe my PP5020AV was just too beastly for it ;) :rofl: :lol:
    savemoney, Chvymn99, cnice_37 and 5 others like this.
  11. Barcroftb
    Barcroftb
    The Mitten
    I've done it that way for probably 20 years. This is much gooder.
    Farmchuck, raybonz, M2theB and 7 others like this.
  12. bocefus78
    bocefus78
    Looks like a good tool for 30 beans. Sure beats drilling the bar and a hard mount!
    savemoney, Chvymn99, Eric VW and 3 others like this.
  13. Barcroftb
    Barcroftb
    The Mitten
    Ed the magnet had a 1.25 inch diameter and a 7/16" width.
    Jon1270, savemoney, Chvymn99 and 5 others like this.
  14. Barcroftb
    Barcroftb
    The Mitten
    I was going to make my own out of a strong magnet and an old arrow shaft cut down to length. The only problem with that rout is I do cutting for other people at different widths.
    Guys I did forget to mention in the original post that I'm not affiliated with Ott and this is all just my unsolicited opinion. I had seen cheeper versions for 10 bucks but they weren't adjustable. After handling and using this one 30 bucks is a fair price.
    raybonz, savemoney, Chvymn99 and 6 others like this.
  15. Handsonautotech
    Handsonautotech
    If you go to the link in OP it starts out showing the stick but ends with him showing off his wood stacks
    :woodsign::stacke:
  16. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Where did you purchase it?
  17. Barcroftb
    Barcroftb
    The Mitten
    Directly off their website.
  18. Backwoods Savage
    Barcroftb I do hope you bring that to the GTG.
  19. HDRock
    savemoney, Chvymn99, Eric VW and 2 others like this.
  20. Barcroftb
    Barcroftb
    The Mitten
    I'm planning on it Dennis!:handshake:
