Calling all saw mechanics
Discussion in 'Chainsaws and Power Equipment' started by CHeath, Mar 3, 2017.
  1. CHeath
    CHeath
    NWNC Mountains
    Ok here's the deal. I got this ms250 for next to nothing. It cranks and runs but won't idle. Idle screw won't do anything. When pulling the handle, it feels like it has too much compression. So I thought it maybe will need a piston.
    Well the piston, crank, oil seals, rings all look really good. Cylinder wall has zero marks. It has a OEM carb and crank but I think the piston is aftermarket. Not sure about the head. Here's my question. The original owner said that it would crank once per day and run fine as long as you kept it running. After it shut off it wouldn't crank again. He removed the carb and cleaned it and put in a new impulse line and new oil seals and it didn't change anything. Idle screw didn't help when adjusting.
    So being it felt like it had too much compression, I was looking for a bind somewhere. The only place I found was possibly where the connecting rod connected to the crank. It has a super wide gap in it and could have a lot of play. I'll upload a pic as well showing the gap. The rod does NOT wobble but it can slide back in 4th on the bearing. What do you guys think? I may just slide a eBay carb on it and try it.
  2. Scotty Overkill
    I'd start out by re-tuning it. Run both the H and L screws down, back the L off by 3/4 turn, the H off by 1 turn for baselines. If that don't work, try cleaning and rebuilding that carb again. Use compressed air to clean it out good. Remove the hi-lo screws and all.
    Sounds to me like it was tuned wrong. I had similar problems on the MS310 I have, it was the carb that was the problem. Bought a 10 dollar Chinese carburetor off of fleabay and that fixed it.......
    As for the side thrust in your rod bearing, that is completely normal. It's actually necessary. Excessive wobble or up-down thrust isn't normal. That's an issue I'm having with my 064.
  3. Mag Craft
    I think Scotty has nailed it. Also like Scotty said the side ways movement is normal on the rod. Problem is the carb.
  4. CHeath
    CHeath
    NWNC Mountains
    Thanks boss fleabay time.
  5. The Wood Wolverine
    Maybe rebuild the carb yourself after it got a bath in an ultrasonic cleaner, with an oe kit. I've used 2 cheapo chy knees kits and I won't buy another. Welsch pug wouldn't fit, metering lever spring was different... never again.
    Horkn likes this.
  6. fox9988
    fox9988
    NW Arkansas 72717
    A friend had similar symptoms out of a two stroke mini tiller last week. Reved out but no idle. Idle jet did nothing.
    I counter the turns to full seat, then backed the idle jet all the way out, blew the hole out with carb cleaner. Set the jet back to the original position. Idled decent. Needed a small adjustment. It had been plugged from setting.
  7. rookie1
    rookie1
    I bought an 044 that the seller said he rebuilt carb and didn't change the way it ran. Stumped him and he thought saw needed something major. I put a new carb on it and it ran great. I'm with Scotty,do the carburetor.
    Horkn likes this.
  8. MasterMech
    You can also check and make sure the impulse path is not blocked by a gasket.
  9. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
    Is this a single screw carb, or does it have both H and L screws along with the LA screw?
  10. Boomstick
    Boomstick Banned
    Saratoga county ny
    Yup the Chinese carbs work great!
    I put them on everything, it's not worth messing with the stock carb. I have a drawer with old carbs off stuff I bought or fixed that the China stuff replaced!
    Kyle Mulligan and rookie1 like this.
  11. HuckFinn
    HuckFinn
    Mt Rainier
    If it feels like it has to much compression, it could be the timing is to far advanced, I bought a Chinese coil on ebay that gave me that problem once or even a sheared key.
  12. The Wood Wolverine
    Chi niece coils are crap. I bought a Huztl one that lasted less than a year (Husky394).
    I've read a lot if negative feedback about the carbs too, so for this guy, it's name brand. My saws are too valuable to skimp, and IMO you are doing just that with cheep ch eye neez parts.
    SKEETER McCLUSKEY likes this.
  13. cwn877
    cwn877
    Central Pa
    I have had similar experiences with 2 small Huskies and it was ignition coils.
  14. Scotty Overkill
    While they may not be ideal, it'll hold up for now. It'll give me time to sonic bath and rebuild the OEM carb when I get a spare moment.....if that ever happens.
    10 bucks for that cheap carb, I've run the living pizz out of that saw the past week and a half and it's working great......so I got my money back already.....lol
  15. HuckFinn
    HuckFinn
    Mt Rainier
    I did get this coil to work by slotting out the mounting holes with a dremel tool and turning the coil (counter clockwise if memory serves) on a 044.
    Horkn likes this.
  16. The Wood Wolverine
    And I get that. The problem is (with those shy neas part) they are very inconsistent. You may get one that lives fo looong time, I may get one that is total chit.
    Can I get some kind of reward for spelling china-man-ese so many different ways, in one thread? Or am I the only won laughing?
  17. CHeath
    CHeath
    NWNC Mountains
    H and LA and idle screw.
  18. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
    The LA is the idle screw, are you getting the L side screw confused with the idle screw? You will have two screws very close (side by side) will be the H and L screws, and one that is by itself (marked LA) is the idle screw. It is easy to assume the L screw is the idle screw because adjusting the L screw will change the air fuel mixture at idle, therefore adjusting idle rpm.
  19. Screwloose
    One thing I don't see mentioned is the non serviceable check valve that is pressed into some carbs. I do NOT know if this saw has one. It looks like a brass plug with a hole in the center. Carb cleaner WILL damage it. Test by pressing a square cut piece of fuel line against it and blowing and sucking. Used fuel line will add flavor. To many times it gets "rodded out" and suffers from chemical warfare.
    CHeath, Horkn, Oldman47 and 1 other person like this.
  20. CHeath
    CHeath
    NWNC Mountains
    I'll check that out thanks a lot
