Help talk me into or out of this tractor!
Discussion in 'Chainsaws and Power Equipment' started by shaggy wood dump hoarder, Feb 25, 2017.
  1. eatonpcat
    Thank you Mag Craft...stupid question, but my drive needs more gravel, but I have some washboard places, Is something like your drag gonna be able to dig up hard a hard packed, neglected drive?
  2. brenndatomu
    Need a box scraper for that
  3. Unicorn1
    Unicorn1
    Amarillo, TX
    I love the old Ford tractors, you can look for Arp tracks for added traction too.
  4. eatonpcat
    Haha...I have one, I guess I was hoping for a less invasive fix! My laziness shines through once again!! Thanks
  5. shaggy wood dump hoarder
    menomonie
    Uufffda, I don't think I'll need that much traction, but a cool picture!
    Just waiting to talk to the guy, he had a hip surgery Monday so I'll give him some time to recover before bothering him, but I will keep everyone posted!
    Dancan likes this.
  6. Mag Craft
    Yep I have a box scraper also. But a lot of the time all the road needs is to drag it which is fast and easy. I do a lot of maintenance on my road because I hate wash board. When I first started on it there big rocks in it and large ruts from rain, but now it is a piece of cake to maintain but it took awhile to get there.
  7. brenndatomu
    But after the box scraper loosens it up I bet a drag would do a dandy job of makin it smooth again!
    Box scraper doesn't always do the best job of making things smooth unless the driveway/road is pretty flat. We have this issue in one of the gravel roads at work, the scraper seems to accentuate the high spots and digs out the low spots. So we rip it up loose with the box scraper and then smooth it out with a standard 3PH blade swung around backwards...works pretty well.
  8. fuelrod
    fuelrod
    Western Maine
    ^^^^ What Butcher said!!
  9. Screwloose
    Box scraper definition--- A box scraper is a tractor implement that lures you into thinking that in one more pass everything will be perfect only to dig in and make a rut that has you circling around and around and...........Till the cycle repeats.
  10. 94BULLITT
    94BULLITT
    Frederick County, VA
    You need a landplane/ grading scraper. fuelrod made a very nice one.
    Sent from my SPH-L710 using Tapatalk
  11. eatonpcat
    fuelrod....Any pictures you would be willing to share of said apparatus??
  12. fuelrod
    fuelrod
    Western Maine
    This is when it was first barely usable, had to try it. April snow& graderblade 143.jpg
    Here it is finished with the 3 point hitch on the front for use with the tractor. The mechanism to adjust the depth of cut is there also, along with what turned out to be the ugliest color paint I had in the shop:rofl: :lol:
    It's heavy, but you want that. Almost 8' wide cut.
  13. eatonpcat
    I would be embarassed to show you what I call my box grader, that thing right there is a beast. Thanks for the photis!
  14. Mag Craft
    That is what I have for a box grader also. Except the one I have also has some scarifiers on it. Nicely done fuelrod.
  15. shaggy wood dump hoarder
    menomonie
    Do 3 points put any down pressure on the attachment? I guess in all my hours on tractors I don't recall, I know my buddies compact doesn't put any force down, only what's there for weight
  16. MasterMech
    Not normally.
  17. eatonpcat
    Mine doesn't!!
  18. brenndatomu
    There are a few tractors out there that have down pressure on the 3PH...but the vast majority don't. Maybe someone knows which ones do...I don't recall any specific models right now.
  19. 94BULLITT
    94BULLITT
    Some old Internationals have down pressure. JD is offering down pressure on some of the new 4000 series.
    Sent from my GT-P3110 using Tapatalk
  20. 94BULLITT
    94BULLITT
    That is actually a "carry all" from Tractor supply. They have a bunch of holes in them to bolt boards to, to make a custom box or platform on. If you google "tractor carry all" it will give you some ideas. A lot of people do use them as forks. I think the carry all is rated to carry 1000lbs. IMO forks are one of the best attachments for a tractor. I use my forks more than anything. I keep all kinds of stuff (including firewood) on pallets. If need something then I can grab up a pallet and haul it to where I need it. If it is in the way it is easy to move with the tractor.
    I built my own forks then took a pallet and made a carry all to haul some saws and tools. That way I can drop my "carry all" quickly and move a pallet if needed.
    Agrisupply has these forks for $200. Shipping probably would not be bad if you don't have a store close by.
    3-Point Pallet Fork, 2,000 Lb. Capacity
    Dancan, Mag Craft, fuelrod and 4 others like this.
