Picked up a splitter today - DHT
Discussion in 'Chainsaws and Power Equipment' started by BetterCallMaul, Feb 28, 2017.
  1. BetterCallMaul
    BetterCallMaul
    SE PA
    Been a busy few days - stove and liner installed Friday, picked up a splitter this morning. Had to test it out.
    DHT 22 ton. $899 minus 5% for Lowes card. Debated on this vs. Ariens 22 ton, but price difference was too hard to justify.
    Sent from my SM-G935V using Tapatalk
    Drvn4wood, Hammy, 94BULLITT and 21 others like this.
  2. Oldman47
    Oldman47
    Illinois
    They sure are pretty when they are new.
    Horkn, eatonpcat, Woodsnwoods and 6 others like this.
  3. mirnldi
    mirnldi
    Ya I was looking at those the other day. They look well built. I have the ariens 22 ton and there hasn't been a log I couldn't split, though I did have a hydro problem the second time I used it. No problems since though
    Horkn, eatonpcat, Woodsnwoods and 5 others like this.
  4. papadave
    That should do nicely. Hydraulics rock.
    Horkn, Woodsnwoods, Blazing and 3 others like this.
  5. Backwoods Savage
    I think that is what Pallet Pete has and it is a good splitter to own. Good for you and congratulations.
  6. Gasifier
    Nice! Hope you enjoy it.
    Horkn, Woodsnwoods, Blazing and 2 others like this.
  7. Warped5
    Warped5
    Northwest IN
    My buddy and I share that exact model.
    Make sure you run it dry before storing like the manual says.
    That POS plastic carburetor is a PITA to work on. Especially when it's zero outside.
  8. Babaganoosh
    Babaganoosh
    Jersey Shore
    I've got the 27 ton. Love it.
  9. Eric VW
  10. Ashwatcher
    Ashwatcher
    West By God Viginia
    Congrats BetterCallMaul - You cant go wrong with Kohler and now you hardly ever have to call maul...Great looking splitter, I'm thinking they make nice wide log cradles too----I'd look for them used...
  11. Blazing
    Blazing
    Sutherland Virginia
    I have the same splitter with the log catcher been a wonderful machine. Picture is me making some smoking wood for a buddy. I just Crack the pieces for him and leave it as a whole chunk. Then he can take his hatchet and knock off what he wants. Disclaimer I normally split vertical with crate lol. 20150523_185916.jpg
  12. Deadwood
    Deadwood
    I'm going through the pre-purchase process myself right now. Congratulations!!
  13. Ashwatcher
    Ashwatcher
    West By God Viginia
    Well Blazing you had me til vertical---thought you had it going on the way its supposed to be split...Anywho-thats my biggest complaint about my Cub splitter, the log catchers are too narrow-wonder if those would fit on mine? Prob need to do research or design my own-have a couple buddies who are welders...
  14. Blazing
    Blazing
    Sutherland Virginia
    It's a real simple design you see the two bolts on top it's the same for the bottom just two straight through the beam. I use it horizontal so long as the rounds aren't over 50 pounds or so. I tried it without the log catcher the first day and absolutely not. This is typical size I get so I roll and flop in the vertical position. 20151025_161944.jpg
  15. Ashwatcher
    Ashwatcher
    West By God Viginia
    I will concede there is a tipping point...pun intended, but you are too young to allow it be 50 lbs...the upper body workout alone makes it worthwhile,,,if you are able---not that there's anything wrong with it...:whistle: I doubt they will fit without alteration, I also like the looks of the ones on TimberWolves...prob just fabricate my own as mine are totally inadequate to maximize splitting
    Eric VW, Horkn and Woodsnwoods like this.
  16. Ashwatcher
    Ashwatcher
    West By God Viginia
    IMG_5030.JPG IMG_5029.JPG Any ideas anyone?
  17. BetterCallMaul
    BetterCallMaul
    SE PA
    I've got to the point that I didn't have the time to continue only handsplitting...and my backlog of rounds was growing.
    Already ordered the log cradle. The work area just absolutely needs it unless you have 3 hands (one to hold one split, one to hold other and another to operate the lever). Definitely looking forward to the cradle.
    Eric VW, Horkn, Ashwatcher and 3 others like this.
  18. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Congrats on the splitter. Highly suggest running ethanol free gas at all times, regardless of how often or not you run it. Check the gibs once in a while if you see some slop as it travels. You will love it. :dex:
  19. Blazing
    Blazing
    Sutherland Virginia
    Trust me I've done bull work all my life started working construction with dad long before most had to worry about washing clothes. Grew up working farms as well for extra cash picking tobacco and pulling weeds. Trust me you don't want to pick it up if you can roll it. You have a perfect platform to bolt or weld a larger catcher on with what you already have now which is a big plus.
  20. Horkn
    Great score! I can't even imagine not having hydraulics to split wood.
    I wouldn't worry about running non ethanol gas. Just run it dry when you are going to put it out of service due a number of months and you'll be just fine. We've been on e10 pretty much exclusively for over 20 years and it's not been an issue, in any internal combustion engine.
    Eric VW and Ashwatcher like this.
