Added OAK to the stove in the cellar adjusted Trim
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Luneyburg, Feb 10, 2017.
  1. bogieb
    I re-read that after a couple of days and I'm like, "what the h3ll was I saying?" :confused:. Oh, that "gelx" is supposed to be "flex" (and it should be "pipe", not "tube ":loco: :crazy:.
    ivanhoe, Luneyburg, imacman and 2 others like this.
  2. jtakeman
    Never write a reply when sober! ;)
    :D
    ivanhoe, imacman, greaser and 5 others like this.
  3. will711
    will711
    Pocono Mts.
    Good advice :drunk:
    ivanhoe, imacman, greaser and 4 others like this.
  4. Lousyweather
    Lousyweather
    LOL- THATS my issue!
    ivanhoe, gbreda, imacman and 6 others like this.
  5. slvrblkk
    slvrblkk
    Northampton, PA
    X2!!!
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Lunney the OAK being plastic is a no no look at the Harman manual all the damm codes can say go ahead but if the Manual says no you are left with an improperly installed stove and thus out of compliance with the code(s) the reason it must be metal is it is possible it will act as a chimney and handle hot exhaust to a certain degree. Yeah tell me all about it.
    jtakeman, bogieb, imacman and 2 others like this.
  7. Luneyburg
    Luneyburg
    Hills of Central Mass
    Well thank you Smokey , its not hooked up to the Harman but you make a compelling case with some very valuable information. Much obliged for your input Smokey and will react accordingly !
