Reworking the house's water system...
Discussion in 'The DIY Room' started by Chvymn99, Feb 11, 2017.
  1. Chvymn99
    After last weeks episode of no flow in the bathtub, plus I've planning on doing something of this nature for a while.
    I've been reading up on PEX water lines, Filtration systems (softeners vs filters) and possibly a tankless water heater (gas style)... I'm going to be getting a water test on my water to see where I stand on hardness.
    What I'd like to see (from my reading - Pros/Cons):
    Water lines comes into the house
    Filtration system (softener *Salt/No Salt* )(Filters)
    PEX water Manifold to disperse water to house (style and make???)(Pipe size/Style of Manifolds *plastic/Brass*/fittings *plastic/brass*)
    Tankless heater (gas)
    My thought is to have all this on one wall in the basement...
  2. lukem
    I'm getting ready to do the same project....Rip out the old galvanized and go PEX.
    :popcorn:
  3. Thor
    Thor
    Genoa City,Wi
    :ithappened: :popcorn:
    Eric VW and Chvymn99 like this.
  4. shaggy wood dump hoarder
    menomonie
    Go pex! You will be a master plumber in 2 hours! So easy, I went with brass, no problems, a couple buddies went with plastic couplings and 90s one or 2 leaks but easy fixes. Nice thing is with pex nothing has to be perfect, that stuff flexes a lot, use it's flex rather than so many 90s it will keep your lines much quieter. Get a manifold on your main line, at least 3/4 supply. I went with 3/4 supply and 3/4 out the end to the washer and the pipes going out of the manifold were 1/2, with individual valves going out of every outlet.
  5. Eric VW
    I need to do that exact thing...get the galvanized gone...
    papadave and Chvymn99 like this.
  6. Highbeam
    Highbeam
    I did it in my house. Recycled the copper for a nice chunk of money. My copper manifolds do not have valves. All home runs.
    Chvymn99 likes this.
  7. CoachSchaller
    CoachSchaller
    Southeast Michigan
    Had to put in a water heater two years ago.... Wanted a tankless but the plumber talked me out of it. He keeps having to go back year after year to replace computer boards on the tankless. We have an old tankless at our hunting cabin - no electronics, just a pilot light. It can be wonderful, just worried about how they are now all computerized :(
  8. chris
    Pert near everything has a chip on it controlling something. It is pricey to set up an adequate surge/ noise /spike system on the AC lines- it has to cover Hot ,Neutral and Earth. The other option is local suppresor / filter at about $50 a pop. Biggest problem with point of use heaters is mineral deposit build up in the heat exchanger tubes. Course that depends a lot on your water supply and what may be dissolved in it. So getting test puts you ahead on that curve. Once you have those # a system can be designed to reduce/ eliminate / neutralize those specifics. Reverse osmosis is way to slow and pricy for a whole house function most of the time.
  9. Canadian border VT
    I'll second or third be careful of tankless.. are they supposed to save money ues.. but any minerals in water.. think something else good friend has put in 3 tankless in 6 years at 2k plus a piece.. I was how much can they possibly save if break every 2 years by your hard water?
    pex heck ya! get a manifold and each appliance on on line too easy if ever a problem shut off are at manifold...
    Minnesota Marty and Chvymn99 like this.
  10. Chvymn99
    Wow... Didn't know that about the tankless water heaters, but haven't put too much research into it... Just figured while I was doing it, It would be ideal time to make the transition. Thanks for the heads up.
  11. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    Once you go PEX you never go back. Manifold or no manifold, not sure. My only advice is spend a few extra $$ on a good crimping tool. I am converting everything in my rentals to pex whenever I can. Pay attention to the details on all fittings.
    On tank less water heaters, I heard the same thing on electronic ones, circuit boards not lasting. I went with a high efficiency 50 gallon direct vent. So far, so good. Momma hasn't run out of hot water yet. and we all know how important that is.
    Canadian border VT and Chvymn99 like this.
  12. Chvymn99
    Can you elaborate, on both of these comments? Just curious what you thinking? Thanks.
  13. TurboDiesel
    I have an electric tankless that has been in for 6-7 years with no problems.
    I put in a softener after putting in the tankless due to our super hard water.
    And I'd do it again
    Check out this thread on waters heaters
    Tankless water heaters
  14. Chvymn99
    ?? .... :handshake:
    TurboDiesel likes this.
  15. TurboDiesel
    its there
  16. Chvymn99
    Yep.... didn't appear there the first time.. thanks... I'll go check it out....:handshake:
  17. TurboDiesel
    only cause my fone wouldn't link it correctly...:whistle:
    had to jump on the pc and fix it :rofl: :lol:
    now...back to your regular programming...
  18. Canadian border VT
    TurboDiesel what do you hear about the electric tank hot water heaters that have heat pump in them.. cannot think of name they are offering 600 dollar off rebates right now and claim avg family of 4 costs 12 dollars a month?
    TurboDiesel and Chvymn99 like this.
  19. chris
    those shark fittings make life with super simple no crimmper needed- don't know how well they hold up as I only just used them a month ago. work for copper, plastic and pex just need to get the right one for the job.
  20. TurboDiesel
    $1200 +
    uses 60% less energy
    slow recovery times.
    still uses electric for high demand
    cant be hidden in a closet because it needs a larger area to pull heat from (up to 1000 cubic ft)
    less efficient in a cold basement because there is less heat there to transfer to the water.
    and it will cool the basement even more
    also needs a drain
