ATV/Mini Skidder
Discussion in 'Chainsaws and Power Equipment' started by jd87, Feb 9, 2017.
  1. Stinny
    Nope... they stay straight with the logs. The front plastic nose sled twists a little tho to let it turn.
  2. 94BULLITT
    94BULLITT
    Frederick County, VA
    Nice job jd87! Once you get the stiffer coil overs on the rear it will probably pull better since it will ride more level.
  3. jfhrtn
    jfhrtn
    Wilson, NC
    Any home made inventions for rolling the logs where you need them?
    T2 Tappin'
    Stinny, Blazing, Horkn and 2 others like this.
  4. Backwoods Savage
    Like a cant hook?
    Horkn, gboutdoors and jfhrtn like this.
  5. jfhrtn
    jfhrtn
    Wilson, NC
    I have been looking at getting a can't hook since I've had two 29" plus oaks back to back. Didn't know if anyone had made a home made one to go along with these awesome skidders
    T2 Tappin'
  6. Backwoods Savage
    I rarely go to the woods without one!
    Blazing, Horkn and gboutdoors like this.
  7. Horkn
    Suzuki did most of the design and engineering on cat ATVs.
    gboutdoors and TurboDiesel like this.
  8. Stinny
    Peavey cant hook to roll logs does a great job. If you have to stack the logs, a cable rigging from years ago called parbuckling can help get r dun. Need a tug if you don't have a horse...
  9. Mr. Twister
    Mr. Twister
    St. Charles, Ontario, Canada
    This is my setup.....works really well for me...easy to maneuver through tight bush trails......Twister Log Arch.JPG
    Loon, Dancan, eatonpcat and 4 others like this.
  10. Stinny
    I'd love to build a lighter version of that concept to set up with tires or snow skis. Nice rig Mr. Twister ... :yes:
    Backwoods Savage and Hammy like this.
