The Barrel Stove Thread
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Deadwood, Feb 12, 2017.
  1. Deadwood
    Deadwood
    Bought a wood stove this summer from a nice guy on Craigslist, cleaning out his dad's garage (passed away). Barrel stove with cast iron door and leg kit, etc. Barely used and no thin metal -- $30. Ready for a flue and getting it installed over the next month or so with a vertical flue going straight up. This will only be used for weekend use and occasional weeknight use in cold months so I figure I should get many years out of it before pinholes develop.
    My BIL and I welded together a frame to sit under it and it's cast iron legs so I wouldn't need to bend over to load wood or clean out ashes.
    Has anyone lined the lower half of these with firebricks? I know these have a relatively short life-span compared to stoves with a cast-iron firebox, so I am looking to extend the lifespan and improve thermal mass of the stove.
    What's everyone else's experience with barrel stoves (the good, bad, ugly)? How long did you own it or how long did it last?
  2. Deadwood
    Deadwood
    I'll take pics of the setup so far. Barrel kit door has initials F.O.K. cast in. No idea what that stands for, but looks more or less like a Vogelzang or USSC kit setup.
  3. Deadwood
    Deadwood
  4. oldspark
    oldspark
    NW Iowa
    I know some people put sand in the bottom to make them last longer.
  5. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    My farming mentor had one of those with the barrel above it as well. I never saw him change a barrel so I'm not sure if his was lined with anything. I have seen it cherry red before though!
  6. chris
    yep sand was always the recommend product for the bottom - sand and firebrick would be better - sand to get a flat spot for bricks to lay on bottom.
  7. Gasifier
    That looks like it would throw some heat. In-expensive heat!:thumbs:
  8. Deadwood
    Deadwood
    Great idea about the sand to flatten the bottom -- I probably would've never thought of that. #OweYouABeer
    metalcuttr, oldspark and Eric VW like this.
  9. Deadwood
    Deadwood
    It looks like it was used at one point for a double-barrel setup, which I wasn't needing, so we MIG'd the mounting holes closed on top. Gonna let it all just rust to a nice brown patina - not bothering with paint.
    metalcuttr and Eric VW like this.
  10. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    My brother worked at a tractor dealer and they heated the shop with a barrel stove for many years.
  11. Eric VW
    We've had one in our Catskills cabin for 30 years (it's still there)....one in the basement in our house on LI, one in my folk's house here in VA & dad's shop... never burned any of them out.:)
  12. Deadwood
    Deadwood
    Great thing is that once the barrel metal wears or "flakes out", you just replace the barrel and cut and drill a few holes.
    metalcuttr, Eric VW and Jack Straw like this.
  13. Deadwood
    Deadwood
    This is good to know! I was a little worried that it would be burned out in a few years. Is this with firebricks lining the bottom?
  14. oldspark
    oldspark
    NW Iowa
    If done right barrel stoves are kinda cool.
  15. Deadwood
    Deadwood
    This is what I am thinking...
  16. Deadwood
    Deadwood
    Except for a layer of sand in lower sixth or so of bottom of stove.
  17. Deadwood
    Deadwood
    What I will probably end up doing to my barrel stove.
  18. Deadwood
    Deadwood
    However, if I could find one of these SS barrels, I just might take the bait and bite.
    isaaccarlson, metalcuttr and Eric VW like this.
  19. Eric VW
    Just sand...never the firebrick. :thumbs:
    metalcuttr and Deadwood like this.
  20. Deadwood
    Deadwood
    How do you keep the inevitable ash and sand separate? Do you just keep replacing sand?
