Another homemade splitter...
Discussion in 'Chainsaws and Power Equipment' started by Deer Meadow Farm, Apr 11, 2016.
  1. Horkn
    Mmmm, trunnion porn.
    Kevin in Ohio and blacksmith like this.
  2. Horkn
    If browsing on your phone or tablet, and you have it vertically set, you don't see the links, or sig lines. Flip the phone or tablet to portrait view, and they magically appear.:yes:
  3. blacksmith
    blacksmith
    central Pa
    Ok gotcha thanks.
  4. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Well, I think my buddy and I managed to straighten the end of the shaft. It's pretty darn close if not perfect. It took a lot of heat to move it though and it looks like I may have a tiny flat spot on the shaft itself from the press; hopefully it's not enough to have it leak. Tonight I'm going to do some more work on it. Best conversation of the night:
    My buddy and I looking at the attachment collar on the push plate...
    Me: "What does it look like?"
    Buddy: "This didn't break; this is a weld failure"
    My buddy then begins to lecture me on required heat, surface prep, penetration, etc.
    Buddy: "Overall this is a pretty crappy looking weld. Did you use your MIG? It looks like you stick-welded it."
    Me: "You welded that for me"
    Buddy: "I did?!? Uh, apparently I didn't have enough heat going to it...":doh:
    Me: :rofl: :lol:
  5. Kevin in Ohio
    Kevin in Ohio
    I agree with your buddy! Oooops. :D Tell him to put the gussets on then as well. No reason not to.
  6. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    I'll be welding it this time. I will add gussets
  7. blacksmith
    blacksmith
    central Pa
    You hust have to love the irony in all of this!:hair::rofl: :lol: Iam sure it will turn out fine. Let us know how you make out!
    Canadian border VT and Horkn like this.
  8. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
  9. Kimberly
    Kimberly
    The Kangaroo State
    Question: Is it better to have the ram pushing the wedge or pushing the push plate?
  10. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    My long term plan is to have split wood fall onto a conveyor so for me it was essential to have the cylinder pushing the push plate.
  11. Kevin in Ohio
    Kevin in Ohio
    It's a loaded question as it depends on the splitter, personal preference and a person's wood gathering operation. They have pluses and minuses and each case has to decide which is best. Some like the Horizontal vertical option so that's wedge on ram. Some like the push through to pile or conveyor. The a pusher. I got tired of all the pull backs.
    With my lifting system, wedge on ram is best as if I had a pusher, every round on the lift would swing back as it was complete which would be dangerous. I use the hanger as a storage till I get the ones on the table done. It boils down to each persons situation or taste.
  12. blacksmith
    blacksmith
    central Pa
    That's one sweet setup there Kevin!
    :dex::thumbs::bug:
  13. fuelrod
    fuelrod
    Western Maine
    Kevin pretty much answered this, but yeah, if you're not splitting through a 4 way wedge of more (like me) you are always chasing your wood back for a 2nd split. With the wedge passing through the wood, your wood stays put for a 2nd pass.
    My rounds are not consistent enough for a 4 way wedge and I'm too "anal" about my split's being mostly equal.:hair:
    blacksmith, Horkn and Kevin in Ohio like this.
  14. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Well, hopefully this works. Added 1/2" thick side plates to the beam, increased the width of the push plate and raised the level of the loading table. No tests yet but it looks pretty damm beefy!
    Table lift kit 1.JPG table lift kit 2.JPG welding side plates 2.JPG Welding side plates1.JPG
    HDRock, reelcrzy, Horkn and 2 others like this.
  15. blacksmith
    blacksmith
    central Pa
    Horkn and Canadian border VT like this.
  16. Kimberly
    Kimberly
    The Kangaroo State
    Good luck.
    blacksmith likes this.
  17. Unicorn1
    Unicorn1
    Amarillo, TX
    Any updates?
    blacksmith and Casper like this.
  18. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Not yet. This weekend hopefully.
  19. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Used the splitter all day Saturday. No issues so far (sound of me knocking on wood here). I split some monsters too so I think I gave it a good test. monster split.JPG
  20. Unicorn1
    Unicorn1
    Amarillo, TX
    We need some video, hope you have no other issues and be safe. :)
