Bore cleaners
Discussion in 'The Game Room' started by Beetle-Kill, Jan 18, 2017.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Anything new out there? Just curious if anyone has come up with an ultimate cleaner?
    I use #9, CLP, foams, all kinds of stuff.
    Anyone have a favorite recipe?
    blacksmith likes this.
  2. lukem
    I don't shoot high round counts compared to a lot of guys, so my gear is never really all that dirty when I clean it. This may not work for everyone, but it works great for me.
    I used to be a Hoppes/Rem Oil guy. Then I switched to CLP. Breakfree is pretty good stuff, but I recently picked up a can of Ballistol (on the recommendation of a waterfowl hunting buddy who's gun is always covered in water and mud) and don't see myself using anything else now. It seems to dissolve carbon just fine and protects very well. The Breakfree works just as well, but was too foamy for my liking...Ballistol is much thinner and easier to soak the bore with. Maybe it was just the can of Breakfree. Dunno.
    I do like using a boresnake on my .22's over a rod/patch. I use rods on my .308 and shotgun.
    Other than that, my cleaning set up is pretty basic. Some patches, poly picks, needle CLP applicators (for pistol rails), CLP, a few lint free rags, and a stiff toothbrush.
    blacksmith and Beetle-Kill like this.
  3. Boomstick
    Boomstick Banned
    Saratoga county ny
    I usually don't clean any bore except when shooting lots of uncoated cast bullets.
    I can usually get 800-1k on a factory Glock barrel if the lead is good before build up.
    My prescision rifles might get cleaned yearly.
    My plinkers if something questionable has been through it I use hops and remoil.
  4. Woodchuck
    Woodchuck
    Southeastern Ohio
    We shoot thousands of rounds 0f 22lr with the 4H Shooting Sports kids. Mostly CCI and Federal Automatch
    Might be some better stuff out there, but Hoppe's #9 and Rem Oil are hard to beat IMHO
    :rootintootin:
  5. bassJAM
    bassJAM
    Cincinnati, OH
    I rarely clean the bores of my guns, but I've always been happy with #9.
    As far as oils, I used to use Rem-oil but after seeing a lot gun oil tests I've stopped. Rem-oil doesn't do much better than WD-40 for rust protection so I switched to Eezox. Hornady One Shot is also apparently very good, as is Break Free CLP.
    Beetle-Kill and blacksmith like this.
  6. blacksmith
    blacksmith
    central Pa
    Me I am with the other guys on the Hoppe's #9 and rem oil. First I soak a bronze bore bursh with the #9, let it sit for a little bit while I clean the rest of the gun up (bolt, action etc.) Then I take two dry patches doubled up and clean the #9 out the bore. I keep running double patches up the barrel till they come out white.
    For the chamber I triple up the patches soak with some #9 to clean the chamber in a twisting action . After that sits for a bit I triple up some dry patches to make the chamber shine. Then a couple more patches down the barrel to catch anything that may have run from the chamber into the barrel.
    I use the 35. Cal patches to clean from a 22.cal to 35. cal. The only caliber that I don't double up on when using these patches are the 22-25 cal. This allows for a nice tight fit into the grooves. If you would just use the one patch as directed and your patches come out white double them up and see how much you missed!
    As for the oil I only use rem oil because it has teflon in it. Eventually the oil will evaporate and leave behind a smooth teflon coating which will not pick up dirt and dust!
    Woodchuck and Beetle-Kill like this.
  7. blacksmith
    blacksmith
    central Pa
    But about once in awhile I use Hoppe's copout to clean that copper fouling left behind. And for the 22 long rifle guy or anyone shooting lead bullets Hoppe's lead out!
  8. Boomstick
    Boomstick Banned
    Saratoga county ny
    I pack remoil in my range bag, I use it to clean actions most of the time.
    The Teflon thing is overrated.
    If you want something that sticks and drys look into one-shot.
  9. Casper
    Casper
    Hello to a fellow Canter's Cave graduate. We do exactly the same thing with ours.
  10. Woodchuck
    Woodchuck
    Southeastern Ohio
    Maybe see you at Canters in April? Should be done hoarding by then :thumbs:
  11. Casper
    Casper
    Not this year, our host range only has facilities and dates available for rifle and archery. If we can get a shotgun or pistol club going in our county I would head back down.
    In the spirit of the thread, Aero Kroil does a pretty good job on heavy leading. I have a GP-100 (Ruger) that I shot tons of home cast bullets through and "might" have been pushing some of them a bit fast. A couple shots of Kroil, let it sit for a couple hours followed by some ChoreBoy wrapped around a brass brush and it was clean as a whistle.
  12. WeldrDave
    I just happen to stumble on this thread, I know it's old but I've been making my own bore cleaner for 25 years now and it's easy and works very well. It's similar to Ed's Red, but I learned it back in the Navy from an avid shooter. It's easy, No matter how much you make break it into 1/4'rs. (Note) If you don't have K-1 Kerosene that can be skipped and just go to 1/3rds. It's Dextron automatic transmission fluid, Xylene or Xylol, "hardware stores carry it", Mineral Spirits and K-1 Kerosene. I usually make it up a pint at a time and put it in a spray bottle. "TRY" not to get it on any of your nice finishes, if you do wipe off quickly and neutralize with some general purpose cleaner. It "could" hurt a nice finish because of the xylene. It gives a real nice cleaning action and lubrication at the same time. This was a method used in the field during WWII and such.
    Also, if you have most of this stuff lying around it beats having to pay $12 bucks for a bottle of #9. :)
