No Longer Available Stihl 041 Super
Discussion in 'Closed Ads' started by wkeev, Jan 23, 2017.
  1. wkeev
    wkeev
    ohio
    I have for sale my 041 Super . This saw starts easy and runs great . This would make a good candidate for a resto project . It's in great shape . Asking 250.00 plus shipping
  2. Scotty Overkill
    Is it a true Super? Any pics of the cylinder assy?
    blacksmith likes this.
  3. wkeev
    wkeev
    ohio
    As far as I know . Is there a way to tell by looking at.
  4. Scotty Overkill
    Yes, if you can get me a pic of the side of the cylinder I can tell if it's a true Super. The 041 Super has long studs that run the entire length of the cylinder, and is fastened down with locknuts around the spark plug hole. A standard 041 has small studs that anchor the cylinder down right at the base only.....
  5. Scotty Overkill
    You may have to pull the air cleaner base off the carb to get a good look at the cylinder ...
  6. wkeev
    wkeev
    ohio
    I pulled the base off but realy can't see the cylinder very good . I have no reason to believe it isn't a super . The serial no is 4411730 . Maybe someone can check this . When you start it up it doesn't sound like a 041 it sounds like a hot rod .
    blacksmith and eatonpcat like this.
  7. Kevin in Ohio
    Kevin in Ohio
  8. Scotty Overkill
    Pull the clutch cover off and look in at the cylinder base.....try and get me a pic...
  9. wkeev
    wkeev
    ohio
    I've looked into the cylinder ,from all angles it's covered up good you can hardly see anything .
  10. Woodporn
    Woodporn
    S. MA
    I's be inclined to buy this if we can see the cylinder bolts....
    Pics pls.
    blacksmith and Scotty Overkill like this.
  11. Scotty Overkill
    I'd have to see the cylinder......I tried to find that serial # on the Internet and I can't.
  12. wkeev
    wkeev
    ohio
    I may try to tear into it this weekend .
    Scotty Overkill likes this.
  13. Scotty Overkill
    If you do and it's a Super, I'm interested...
  14. wkeev
    wkeev
    ohio
    I stopped at a dealer today . He wasn't able to help with number ,to old I guess.
  15. Scotty Overkill
    Yeah the serial #'s don't tell too much in regards to specific stuff.
  16. Woodporn
    Woodporn
    S. MA
    Wkeev, any updates?
  17. wkeev
    wkeev
    ohio
    No time today hopefully tommorow.
  18. wkeev
    wkeev
    ohio
    It's a super !! I'll sell to the first PM I get .
    Wayne
  19. Woodporn
    Woodporn
    S. MA
    Yeeeee-hoooooo!
    Sent from my Pixel using Tapatalk
    eatonpcat likes this.
  20. wkeev
    wkeev
    ohio
    Sold
    eatonpcat and Chvymn99 like this.
