Aaaaaahhhhh......
Discussion in 'Modern EPA Stoves and Fireplaces' started by BrianK, Feb 12, 2014.
  1. BrianK
    BrianK
    West central PA
    Some nice combo secondaries in Hi Def in the Ideal Steel stove tonight, burning cherry:
  2. nate
    nate Banned
    Palmer, AK
    Normal to have flames like that?
    If I let my stove run like that I'd probably burn down the house!
  3. BrianK
    BrianK
    West central PA
    Yes, if I need a lot of heat out of it, I'll let it go at that rate for an hour or two. It will chew through a good bit of wood burning at that rate. Its -3 here now so I needed to kick the heat output up for a while before heading up to bed.
    But what you're seeing is the rolling cat secondaries after cutting the air back from 100% to 50% then down to about 40%.
  4. ZeeB
    ZeeB
    I could sit and watch those for hours on end.
    Stinny and BrianK like this.
  5. oldspark
    oldspark
    NW Iowa
    Yea if you want heat you are going to see some flames, I still see posts about lazy secondary flames dancing in the fire box, that's great if you just are looking for a visual effect, I could play a DVD on the TV that would give me that.
    blujacket likes this.
  6. golf66
    golf66
    Good stuff Brian. One thing I wanted to ask you about was that in your photos with the Ideal, it seems to be placed relatively close to the wall in terms of corner clearances. I can't tell for sure from the photos, but the walls look to be ordinary sheetrock and there is wood trim in proximity. Have you checked the wall temp, either with an IR gun or by touching them? I'm very interested in the Ideal, but corner clearances will be an issue.
  7. BrianK
    BrianK
    West central PA
    Originally the left rear corner was about 9" from the wooden door frame. IR temps on the wood were pushing into the 150s early on before I had run any really hot burns, so I moved the stove 4" further out into the room. Clearances now are about 12" on left rear corner, 13" right rear corner. On my hottest burns the door frame has hit the mid 160s on IR.
    UL-127 Temperature limits on combustible surfaces are 90F over ambient room temperature for unexposed (ie., in contact and covered) surfaces and 117F over ambient room temperatures for surface exposed to ambient air so if room temp is 72, combustible temps up to 189 are permissible.
    Woodstock tries to keep recommended clearances so that surface temps are at 150 or below. Last I talked to them they had not yet received the UL clearances for this stove but they were also working on a rear heat shield to keep clearances as low as possible.
    papadave and Beetle-Kill like this.
  8. golf66
    golf66
    thanks for the reply Brian. It looks like they have a real winner with the Ideal and my bank account has room to buy one.
  9. nate
    nate Banned
    Palmer, AK
    Guess the Blaze King runs a bit different. I assumed EPA stoves were all about the same with a smoldering burn.
    If I ran my stove with the air open enough to have flames like in the vid it would peg out the temp gauges. Only times I have flames is when I first have a fire going.
  10. oldspark
    oldspark
    NW Iowa
    Cats are a different animal.
    But even BK owners report having flames if they need a lot of heat.
    Smoldering burn even in a EPA stove is not good.
  11. oldspark
    oldspark
    NW Iowa
    This is from woodheat.org, a website with a ton of good info. Probably more aimed at non cat.
    "Look for these signs of good combustion:
    • When wood burns it should be flaming until only charcoal remains. If there are no flames, something is wrong
    • If there are firebricks in the firebox, they should be tan in color, never black.
    • Steel or cast iron parts in the firebox should be light to dark brown, never black and shiny.
    • With seasoned wood, correct air settings and proper loading arrangement you should expect almost instant ignition of a new load of wood - a long delay before ignitions indicates that something is wrong.
    • If the appliance has a glass door with air wash, it should be clear.
    • If the appliance has a glass door without air wash, it will be hazy, but should never be totally black.
    • The exhaust coming from the top of the chimney should be clear or white. A plume of blue or gray smoke indicates smoldering, poor combustion, air pollution and probably low system operating temperatures."
  12. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Brian, what sorta flue temps. are you reading on a burn like that?
  13. TurboDiesel
    Gheez! I could feel the heat coming off my computer screen from those flames !
    Backwoods Savage and BrianK like this.
  14. BrianK
    BrianK
    West central PA
    When it's running on full air, probe flue temps have gotten as high as 750. Running a prolonged high rate of 50% air the flue probe will read 650.
    Routine flue probe temps run in the 350-400 range.
    A couple weeks ago a friend was visiting and between him and my son they left the door open a hair on a reload and failed to engage the cat in a timely fashion. Flue probe temp hit 1000. Hopefully that's the last time that happens.
    Beetle-Kill likes this.
  15. BrianK
    BrianK
    West central PA
    I took a 6 1/2 minute video then edited it down to its current length. The iPhone was already getting hot to the touch at that point. o_O
    By the way if you click on the YouTube link then set it for highest definition and run it on full screen mode it's pretty impressive. I've never uploaded a video on the highest definition setting, took a long time to upload but it made for nice detail.
  16. Beetle-Kill
    Beetle-Kill
    Have you noticed any build up in the flue so far? I check mine with a flashlight and a hand mirror.
  17. BrianK
    BrianK
    West central PA
    Usually I clean the flue the first week of January but I cleaned it when I installed this new stove in late November so I haven't even looked at it yet. Honestly given the hybrid tech and the double wall stove pipe I expect less creosote than I got with my Fireview so I wasn't in any hurry to clean the flue.
    Beetle-Kill and milleo like this.
  18. swags
    swags Moderator
    When running my BK at higher temps I have flames. My stove is running at about 550 right now at the stove top and there are flames in the stove. Air is around 40-45% (just under 2 on the BK)with a load of locust and mulberry. There are flames in the box but not near where they are in that video. Not a bad thing at all in my opinion just different stoves. I am curious though with other BK owners as to what flames they see. This is my first year with a cat stove so still learning. Pic for reference on the flames.
    BrianK likes this.
  19. Beetle-Kill
    Beetle-Kill
    Swags, I'm thinking the wood will be more of a factor than anything. I get plenty of flame with the BKK wide open upon start with a fresh load, but I have to cut it back within 30 min. or I'll get the CAT to hot.
    I took the cover off the flapper housing and now adjust by sight, don't even pay attention to the dial. The stove goes dark quickly but the temps. rise. I normally get a 475-500 stove top and the Cat Probe will be in the upper end of the active range. Flue will stay about 4-450. That's with dbl. wall and a probe. Those temps. are with the fans going on High, so I'd read higher if they were off. I never shut the fans of.
  20. DexterDay
    With a good light show my stove top is still HOT! Towards the very end of the video, I show my Probe in my double wal. For just a light show, I think you'll be impressed.
    Maybe my stove, flue is the exception. Because most Secondary videos I see are only a few seconds long? (Anyone can get the box hot and close the air for a few seconds and have a light show). It takes good wood and good technique to sustain it for a couple/few hrs.
    Long video. But proves many wrong. Not only is my stove COOKING, But the flue gasses are HOT as heck too. Typical 30 burn.
    mepellet, papadave and BrianK like this.
