Anyone use a Caframo Ecofan?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Thoreau's cabin, Feb 11, 2014.
  1. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    Title says it all
  2. papadave
    Pricey.
    I know someone who has one, but never paid much attention to how well it works moving air.
  3. BrowningBAR
    BrowningBAR
    San Tan Valley, AZ
    I bought one five years ago. It lasted two or three winters. Did not move much air. Worked better in the kitchen location than the den for moving heat. Not worth the price if you are hoping to move heat around.
    Mine was also the larger, three blade, fan.
  4. Stinny
    Have 2 of them on top of our wood stove in our little cabin. They're amazing. Drives the heat under the loft easily. Set them at the rear of the stove blowing over the top and watch em rip.
  5. Backwoods Savage
    In a small cabin it might be okay but they are mostly a novelty. My wife picked at me for a long time so I finally gave in and told her to get one. Two days later, it was returned. She thought it would help circulate the air. Just look at how small it is and realize that it does not turn all that fast either. If it did turn fast, the small blades would be very noisy too. I'd pass.
    yooperdave, nate and raybonz like this.
  6. Stinny
    BackSav… not sure what happened with your fans. Also, not sure about the surface heat on top of the stove. Ours gets very hot on top and the fans sit at the very back. They draw cool air from behind the stove and I guess the heat from the stove creates the power to run them. Ours will get rotating more than fast enough to drive the heat 15'-20' out in front of the stove. Don't know how long they'll last but we really noticed a huge difference in distribution of the heat. It was just going straight up to the peak of the roof making the loft too warm and the downstairs too cold.
  7. Backwoods Savage
    Stinny, in a small room you very well may feel good air movement and that is why I say in a small cabin it might work nicely. Also in a tent if someone is maybe on a hunt it could be good. But one also has to keep in mind that it is very difficult to drive warm air into cooler air. This is why in nature when the cold fronts come out of Canada, they can really be strong and push the warmer air out fast. The same in the house and that is why we tell folks to move the cool air and not the warm. In effect, if you are moving some cool air into the warmer air, it will force the warm air out to be replaced with the cooler air. We blow close to the floor and the heat is driven out up top. It creates a natural flow very quickly because when some air gets replaced with some other, some air has to get out to make room for the new.
    How long they could last would be difficult to determine. I would assume a sealed bearing and for that slow of a movement I would expect it to last quite some time.
    Maina and clemsonfor like this.
  8. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    Ok, think I may play around and make one. Just gotta find me a Seebeck generator. It's on the list, just not at the top.:cool:
  9. Stinny
    I'd say, when the stove is good and hot, these fans are pushing almost the same air as a 6" muffin fan. They are not turning slow, that's for sure. A muffin fan would be better, but we don't have power. Works great for the cabin.
  10. mike holton
    mike holton
    Old Dominion
    seems to be a "teg" powered fan, teg's convert thermal energy into electricity (dc im sure) which powers a small motor to drive the fan. the differential temp across the teg is what creates the current, the higher the "delta T" the faster the fan spins.
    strikes me they wouldnt knock a picture off the wall across the room, but they would stir the air to some extent. biggest limitation is the amount of current the teg can generate, the fan is necessarily lightweight with such a small motor.
  11. Stinny
    Yup, it's a pretty interesting concept. The more differential in temp, the better. That's why it works best (with a hot stove) with it sitting right on the rear edge of the stove… where it can get as cool air as possible to draw from at the rear of the stove, while the base of the fan sits right on the hot stove top. Base of the unit is hot while those fins up top get the cooler air, pulled thru them from the rear. If they were placed in any other position on a stove, I'm sure they would be considered duds. The stove I have at home probably wouldn't work as well because the top surface, near the rear of the stove, is raised a bit, and doesn't get as hot as the lower front surface.
    They're pretty quiet too. All you hear are the blades moving air… no motor sounds.
  12. mike holton
    mike holton
    Old Dominion
    there were some fellows at the DC thing that were demonstrating a camp stove wich was about the size of a coffee can which had a teg mounted to use to charge cell phones and such. its an amazing litle tidbit of technology
    Stinny likes this.
  13. NW Walker
    NW Walker
    Olympic Peninsula
    You can make one for less than $20 if you are handy. I made a video that shows how I built a little reading light, and it touches on the fan project as well. I posted it in Adam's Hoarder's TV thread a while ago. It's here....
    greendohn likes this.
  14. bushpilot
    bushpilot
    Eastern Washington
    Waking up a dead thread, but my wife wanted one of these, and I was skeptical. She found one for about $50, and someone had given us that amount as a gift, so we bought it. This is the model we have Caframo 800CAXBX Limited Original Ecofan.
    Surprisingly, I really like it. It does not "blow" a lot of air around, but I think it does help circulate it in the way we wish. Perhaps as much, it is easy to see how the stovetop temp is doing from across the room by how fast it is turning.
    For $100 plus, no thanks, but I like ours for the price we paid. I may buy a secong, and set it on the other side of the stove.
    Greg
    wildwest and Stinny like this.
  15. jo191145
    I had one. It helped stir the atmosphere in the house just enough to get some extra heat into the master bedroom. Pretty expensive but I liked it. Didn't last a whole season though. I think I got it too hot.
  16. Stinny
    Have 2 of those in our cabin. Love em. They make all the difference in moving the heated air under the loft area. Turned em sideways here while I cooked some hobo hash fer lunch.
    rayvil, Brad38, wildwest and 2 others like this.
  17. Backwoods Savage
    They won't do much but can't do any harm. If you like it, then great. But if you really want to move heat around, the best way still is to move the cool air toward the warm and there is a good reason why it works. But, one has to do it gently; that is, low speed with a small fan else the draft it could produce in the house would be uncomfortable.
    wildwest and yooperdave like this.
  18. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I had one but it did not work well with the "waffle top" of my Jotul f 100. The top of the Castine is pretty flat, so I may borrow it back from my brother to try it.
    My stove is 3/4 in my fireplace, so I'm thinking it can help move some air out of the firebox from the stove top and behind it. There is really no room for an electric blower.
    I hear they need to be kept clean for
    longer life.
    I like the black blades on them. Used to have gold or silver.
  19. Stinny
    They do need that flat hot surface near the rear so they can blow the air forward over the rest of the stove top. The cooler the air coming from the back of the fan vs the hotter surface, the better... when our stove is cranking, those fans are moving some air.
    wildwest and bushpilot like this.
  20. fishingpol
    fishingpol
    I am usually running 500 stove top, I'll have to measure the air temp.
    Stinny likes this.
