How will a modern insert heat with no electricity?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Unicorn1, Jan 12, 2017.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    I'm doing some research on a modern insert and have a few questions. The main reason for installing an insert is if/when we lose power I'll still have a heat source. I still haven't ruled out a vintage Fisher insert. :)
    1. What kind of heat output will I get when the blower can't run?
    2. House is about 2000 sq ft with an open first living room that flows into the kitchen and an open mud room on the back side the the first living room. There's a second 400 sq ft media room that has double hung doors off the first living room too. Isolated master bedroom on one side and two other bedrooms and bath on the other side. Wondering on stove sizing here?
    I'll post some pics when the bathroom remodel is finished and I can get everything put back into place. :(.:(
    Thank you FHC this is a great site. ")
    Horkn, Thor, Backwoods Savage and 2 others like this.
  2. cnice_37
    cnice_37
    Without my blower I lose a lot of heat but it does work. If I load the box up full, without a blower it will start glowing on top.
    Maybe consider a screen in the event of no power, keep the door open just burn more wood that way.
    Horkn, Russell, oldspark and 2 others like this.
  3. Unicorn1
    Unicorn1
    Amarillo, TX
    I'd be ok with a small gen set as that would power a stove blower.
    Russell, KsKent, Horkn and 5 others like this.
  4. fox9988
    fox9988
    NW Arkansas 72717
    A friend heats his shop with a free standing Country Flame insert. Even free standing, it doesn't produce much heat without the blower being double walled construction. Without the blower, the fire box will get so hot that the double doors will bind up and not want to open. Works good with the blower going and a box fan behind it.
    Horkn, Thor and Backwoods Savage like this.
  5. fortydegnorth
    fortydegnorth
    Kettering Ohio
    I had a Clydesdale insert and without the blower I'd say it was pretty pathetic. If you're using an insert I'd think a small generator to run the blower would be best.
  6. fox9988
    fox9988
    NW Arkansas 72717
    A 12 volt inverter is another option. Quieter and cheaper to buy/operate.
    Horkn, BCB, Thor and 1 other person like this.
  7. Unicorn1
    Unicorn1
    Amarillo, TX
    I picked up a used Country Flame with combuster a few years ago but never installed it, I bought a new honeycomb combustor, door seal etc and its just sitting in my shop, its needs two new fans.:(
  8. Ronaldo
    Ronaldo
    You may not get great amounts of heat with no electricity, but I'll bet it is enough to keep things from freezing. I have freestanding stove and it works better with a floor fan behind it, but even with no fan it's a heat source to keep house and family warm.
    Sent from my Z832 using Tapatalk
    Ou812, Horkn, Thor and 1 other person like this.
  9. stuckinthemuck
    stuckinthemuck
    The blower on my Buck draws 200W. I have a Diehard 750w inverter and a couple deep cycle batteries that I got for free. This setup could easily run the blower for hours as well as provide power for a light or two. Another option is to run the inverter off a car battery for a short time, but be ready to jump the car if you drain the battery too much. Without the blower, my house would likely cool down significantly.
    This is the one I have.
    DieHard Electric 750W Power Inverter with USB - Walmart.com
    Horkn, Thor, milleo and 1 other person like this.
  10. Unicorn1
    Unicorn1
    Amarillo, TX
    What insert does the FHC like?
    Horkn, TurboDiesel and Thor like this.
  11. blacktail
    blacktail
    PNW
    All depends on the make/model and the house layout. I've used my Republic insert during power outages and it still puts out heat. But it's in a terrible location in a back corner of the house. Without the blower it takes a lot longer for the heat to move out of that back corner.
    Horkn likes this.
  12. Kimberly
    Kimberly
    The Kangaroo State
    Good idea, and can be used inside at the stove.
    Horkn likes this.
  13. Kimberly
    Kimberly
    The Kangaroo State
    Oh, I see; it is the fans that is keeping you from using the stove. You might can find suitable fans on ebay; you may not need exact replacements.
    Horkn likes this.
  14. Unicorn1
    Unicorn1
    Amarillo, TX
    Horkn likes this.
  15. TurboDiesel
    I'd look for a new hybrid from a reputable wood stove manufacturer
    Horkn likes this.
  16. BCB
    BCB
    USA
    I ran a Regency I3100 from 2009-2016 and really liked it. I picked it up barely used on CL for $600. I think the liner cost me $900 so for $1500 I was all set. With high oil prices back then in a very poorly insulated house it paid for itself after the 1st winter in savings from not having to buy oil. I bought oil only 3xs (150 gallons each time) from 2010-2016.
    Horkn likes this.
  17. BrianK
    BrianK
    West central PA
    Woodstock supposedly has an insert in development too...
  18. chance04
    chance04
    Denton Md
    Where are these little tid bits of info coming from?
    Canadian border VT and Horkn like this.
  19. Kimberly
    Kimberly
    The Kangaroo State
    Horkn likes this.
  20. T-Stew
    T-Stew
    My insert was pretty pathetic without the fans running. It was also a flush insert, and even in the front had an extra cast iron jacket over the little bit of face that was showing. An insert that sticks out onto the hearth will radiate more than a flush one. Then again mine struggled with the blowers fully on too. I was really surprised how much better the freestanding stove works with no blowers at all compared to the insert even with it's blowers going. Of course the Woodstock is about a cubic foot bigger firebox than my Jotul insert was. It's so nice sitting beside the stove with it completly silent. Wish I would have done the switch sooner but the ex wouldn't have wanted the big stove sticking way out. So I know you probably don't want to but I have to suggest putting a freestanding stove in there instead. Just my $0.02
    Canadian border VT and cnice_37 like this.
