  1. ECsaws
    ECsaws
    just picked up a second hand pc45 and. 1200 bay are they worth a hoot ?
    Russell, DexterDay, eatonpcat and 6 others like this.
  2. Dpopps
    Dpopps
    MI
    There not any good, I'll pick them up tomorrow for ya.
    Bags, Russell, DexterDay and 8 others like this.
  3. Dpopps
    Dpopps
    MI
    Oops forgot to put :rofl: :lol:
    Those both sound like nice stoves, expecially if you got a good deal.
    Both of them work good? Nice find.
    Russell, DexterDay, will711 and 6 others like this.
  4. ECsaws
    ECsaws
    Lot to learn with the pc45 yet but I really like the 1200
  5. ECsaws
    ECsaws
    With the 45 it has two burn pots one big hole one small any advise on what to use ?
    Russell, bogieb, IHATEPROPANE and 5 others like this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    I have the Quad...if you have any questions, hit me up.
    Russell, DexterDay, eatonpcat and 5 others like this.
  7. badbob
    badbob
    Bags, Russell, eatonpcat and 7 others like this.
  8. IHATEPROPANE
    IHATEPROPANE
    Haven't seen much said about the 45. Maybe you can give us a review once you get it running? The 1200 is a nice heater. No hi/lo option is the only downside imho.
    Russell, eatonpcat, slvrblkk and 3 others like this.
  9. will711
    will711
    Pocono Mts.
    Basically a p43 with the multi fuel option I believe . Another wood burner coming over to the pellet side ECsaws you are in the right place , lots of knowledgeable folks here ready to help :thumbs:
    Russell, savemoney, DexterDay and 4 others like this.
  10. badbob
    badbob
    Maybe it is one of those rare p45r models,that can burn rocks!! :D:D:cheers:
  11. JZM2CC
    JZM2CC
    PC-45 shares chassis with P61. P43 has same chassis as P38.
    Do you plan on burning pellets or something else like corn, cherry pits, mix of the above? I only use pellets in mine with large hole pellet pot and pellet end gate so ash can fall off edge of pot. Currently using small hole exhaust cover to hold in more heat, but supposed to use large hole cover per instructions. Works quite well i must say. Igniter and air pump are inoperative so I use in Room mode with manual setting so it doesn't shut off.
    CleanFire, Bags, Russell and 6 others like this.
  12. jtakeman
    Welcome JZM2CC. Good to know we have a PC45 owner in the group!
    CleanFire, Bags, Russell and 5 others like this.
  13. ECsaws
    ECsaws
    The plan is to just burn pellets, mine has the large hole pot in it now I'm not sure what you mean by exhaust cover ?
    I don't have a room probe so I'm running on stove temp. I take it I'd be happier in room temp mode ?
  14. badbob
    badbob
    Room mode is a setting on the control board.In addition to the differen pots,there is a restrictor to go into the exhaust blower,unless,possibly yours is really old and different?Never seen one out here,look at the pictures in the manual and see if the pot parts look the same.
  15. ECsaws
    ECsaws
    thanks so far I'm likening them . But I do think the 1200 works a little better, maybe once I learn this 45 that may change.
    I haven't burnt wood in a few years my back doc said enough is enough
    Russell, slvrblkk, ivanhoe and 2 others like this.
  16. ECsaws
    ECsaws
    I "think" you have to have a temp probe to run in room mode ????
    If not something is wrong with mine , it won't run in room settings only stove
  17. badbob
    badbob
    yep temp probe,should be a connector on back of stove takes 1/4" spade connectors,some harmans will not run in room temp mode without it.
    Bags, Russell, Lousyweather and 3 others like this.
  18. will711
    will711
    Pocono Mts.
    Russell, slvrblkk, ivanhoe and 3 others like this.
  19. will711
    will711
    Pocono Mts.
    Not necessarily , I prefer stove temp mode if you want a probe I'll be happy to send you one of mine .
  20. ECsaws
    ECsaws
    What kind of settings should I be using ?
    Rite how feed is on 4 , temp is on 75 fan is on h
    I ordered a probe
    IHATEPROPANE and ivanhoe like this.
