Home Construction Question?
Discussion in 'The DIY Room' started by CuckooChris, Jan 10, 2017.
  1. CuckooChris
    CuckooChris
    Eastern PA
    Hi all! Just realized that the home we bought almost six years ago (built 1977) doesn't have plywood on the exterior under the siding. Looks like it's just framed and then a 1" insulation board was installed on the outside and then the siding. It's freaking me out a little that there's no plywood. Should I be worried?
  2. ironpony
    ironpony
    Mid Ohio
    No, this was a common practice for a while and is making a comeback. This was done to increase R value, if it was done correctly the corners are plywood/OSB and there should be steel diagonal "T" bracing in certain areas. Yes if you are use to normal frame construction it is a little surprising when you first see it. My thoughts always were, vinyl siding, styrofoam then drywall, I can almost walk thru that wall. The vinyl is the toughest part.
  3. Viking80
    Viking80
    Norway
    As long as it's dry the house was won't "fall down". But you might want to look into some form of after isolation and other measures to get the house more airtight?
    blacksmith likes this.
  4. ironpony
    ironpony
    Mid Ohio
    The other thing is if you go to replace windows or doors the jambs are usually thicker because the foam is 1 inch and OSB would be 1/2 inch.
  5. will711
    will711
    Pocono Mts.
    That's how mine was built 1991 , and it was wrapped in Tyvek no issues here .
  6. CuckooChris
    CuckooChris
    Eastern PA
    Thank You! That's exactly what I was hoping to hear!
  7. Canadian border VT
    This is true.. my thought was... what security is it to lock door? when a knife can cut right thru..
    Chris... just look to see where metal braces are and make sure they did not cut them for Windows and doors!
    blacksmith and Scotty Overkill like this.
  8. CuckooChris
    CuckooChris
    Eastern PA
    It's definitely dry... too dry. My basement where the wood stove is gets down into the teens (RH). Rest of the house is 30% at best. I had my whole house humidifier running for two days straight and I think I gained 1%. Most likely because I need new windows on the first floor.
  9. CuckooChris
    CuckooChris
    Eastern PA
    Thanks for planting that seed.:hair:
    papadave likes this.
  10. Viking80
    Viking80
    Norway
    How does it increase the R value?
  11. Canadian border VT
    they use 1 inch foam board instead of half inch plywood.. 1 inch board has r value of about 5 .. plywood .33? in 5 star construction it's is glued to 2 by 4 which are 24 inches on center instead of 16.. also thicker so a 2 by 4 studs with foam and drywall are same width as a standard 2 by 6 wall.. so normal depth windows and doors fit..
    Viking80 does our stud sizes make sense to you a 2 by 4 would be rough cut then planed so it actually is only 1.5 inches by 3.5 inches by length of feet... about 2.2 cm per inch
    will711 likes this.
  12. papadave
    RH in winter is going to be fairly low, unless you add moisture....which you've tried.
    A lot of us have pots of water or some other water vessel on the wood stove all winter to help. The RH in here is 30% right now, and it sometimes drops down into the high 20s, even with the water on the stove.
  13. Viking80
    Viking80
    Norway
    Hey, thanks for asking! Firstly thanks for clarifying the thicker foam board vs. the thinner plywood.
    Here's an illustration of how it's often done here:
    And yes; it's still called a 2x4 here too, even if it's not a literal 2x4 anymore. However the proper measurements for a "2x4" here in Norway is 48mm x 96 mm (planed).
  14. bushpilot
    bushpilot
    Eastern Washington
    Mine had NOTHING between the siding and the insulation! No OSB, plywood, foam, or even Tyvek. So it went - siding, insulation (unfaced), drywall.
    This kind of siding:
    Do you think it might have leaked a little air? :hair:
  15. billb3
    milleo and papadave like this.
  16. Viking80
    Viking80
    Norway
    Is that "hurricane-testing"?
    billb3 likes this.
  17. chris
    Ain't a true test till they start launching the frozen chickens at it.:rofl: :lol:
    milleo, TBONE, papadave and 2 others like this.
  18. billb3
    ICF wall hurricane test 100mph I think
    They also shoot thru conventional 2x4 stud walls with plywood and/or green wall sheathing . Right thru. at 75 mph.
    No sheathing can't be very much protection from much of anything.
    Maybe in a tornado it is better that the sheathing blows away leaving bare studs.
    Viking80 likes this.
  19. billb3
    yooperdave likes this.
  20. ironpony
    ironpony
    Mid Ohio
    We actually used fresh chickens shot out of a chicken cannon at aircraft windscreens. What a mess.
    Jack Straw and papadave like this.
