This is a very strange case of a flashing # 2 light Stove is in good shape but igniter is dead and stove is lit manually and was working. I strongly recommend an inline fuse if new igniter is installed to protect control panel; 1. Cleaned Stove 2. Replaced vacuum switch & vacuum hose and high limit switch. Installed Tripp-Lite Isoblok serge protector where no protecter was before. Still no luck. 4. Installed new updated rev 3 control panel with button boarder markings. Stove ran for one week then # 2 flashing light! Exhaust Blower was noisy. 5. Replaced exhaust blower with new Fasco motor and lighter tall blade with no round backing plate. Plate adds a lot of extra weight that increases start up current! 6. Stove ran longer, about 45 min. Flashing # 2 light. Notice fire door was loose! 7. Replaced control panel (will test other one) again and unplugged dead igniter. Stove is now running fine!! This was a tough one! ^&*^%&(!!! Any comments? Pic 1 - 3 - new updated control panel Pic 4 - 5 old Exhaust blower Pic 6 - new impeller blade Pic 7 - Fire!
Lets see the auger flite cover at the top, a gap there can cause a "loss" of vacuum, a loose seal around the door( not closed tightly ). Hopper not closed as well may cause it. Over heated exhaust blower. How many more do I have to list?
Hello Thanks for your comments, Looks like the exhaust blower was really messing things up! A new control panel and a good surge protector helped!
