Digging these Geneva
Discussion in 'The Pellet Bag' started by Luneyburg, Jan 3, 2017.
  1. Luneyburg
    Luneyburg
    Hills of Central Mass
    Did not experience any issues like that actually was the least stubborn ash out of any of the pellets I have burned . Probably the worst was MWP which was not bad at all. Different stoves like different pellets so I have found out here but this Stove burns them all and the ash content varies minimal and the heat output is the same for almost all except my experience with the Geneva . Even with the softies I burned the ash output was nearly the same,going to grab a few bags of Lacrete's and see what happens . And I could not agree anymore peterfield much much much less work that a wood stove !
    Thanks
  2. will711
    will711
    Pocono Mts.
    As a long time wood burner who made the switch agree 100% :thumbs:
    CleanFire, bogieb, jtakeman and 2 others like this.
  3. ttdberg
    ttdberg Pellet Pig
    CT
    :popcorn:
  4. Lousyweather
    Lousyweather
    they do that, but Luney (so far) keep his stove clean, so wont be much of a problem for him. This is certainly a good point and issue for the multitudes of OTHER users who do not clean the burn pot.....that carbon grows......
    CleanFire and slvrblkk like this.
  5. bogieb
    Ah, much better. I was pretty sure you had mentioned what you had before, and was thinking it wasn't a Harman. Nothing wrong with having a cheap stove - plenty of people have those and have absolutely no problems with them. And, roofs are kinda important to keeping other things you value dry :yes:
