It's in the garage
Discussion in 'Modern EPA Stoves and Fireplaces' started by Bill in the UP, Jan 4, 2017.
  1. Bill in the UP
    Bill in the UP
    Marquette Mi
    Took advantage of the dry roads today and picked up the Sirocco 30.1. I plan to bring it in from the garage tomorrow. No word from the chimney contractor yet. How is it possible to cut through the roof and fit a flashing when the asphalt shingles are brittle from the cold temps? It was 11 degrees today.
  2. Well Seasoned
    The shingles should be fine, we do it all the time. A sharp bit on a jig saw should do the trick. Congrats! Take lots of pics!
  3. TBONE
    TBONE
    Carey, Ohio
    Congrats!! Can't wait to see pics and to hear about the new stove.
  4. yooperdave
    Make sure to work the shingles slowly.
    Yes, they do break easier in the cold.....and yes, it can be done-carefully though.
  5. Scotty Overkill
    A propane torch, used CORRECTLY AND PATIENTLY, can be a big help with frozen shingles.
  6. papadave
    Ok Bill,....you suck.
    Man, I can't wait for you to get that up and running.
    You have a dealer up in the UP?
  7. Eric VW
    Said no intern....ever.
  8. papadave
  9. bushpilot
    bushpilot
    Eastern Washington
    My 30-NC sat in my garage for a whole heating season. Don't let that happen to you.:BrianK:
    Tonight it is -5 outside, and 70 inside. Getting the overnight burn established, all is well.
  10. Bill in the UP
    Bill in the UP
    Marquette Mi
    No, I drove to northern Wisconsin. Best Buy Liquors.
  11. Bill in the UP
    Bill in the UP
    Marquette Mi
    Appreciate the encouragement and information (well, "you suck" doesn't quite qualify).
  12. yooperdave
    Bill in the UP if you had 11 on Wed, you did well. Never got above zero all day here.
