sassafrass?
Discussion in 'The Wood Pile' started by bang, Jan 1, 2017.
  1. bang
    bang
    South central Indiana
    I have a sassafras leaner next to my driveway that has several woodpecker holes in it. I'm going to drop it so I don't have to deal with it at the wrong time. It's about 14" at the base. Is it worth splitting and burning?
  2. Eric VW
    Yep.... at least for the smoker, fire pit, shoulder season.....after all, it's wood, so go for it!:thumbs:
  3. Well Seasoned
    Makes good kindling and shoulder season wood. When burning, it'll be like fireworks in the stove. Smells nice while splitting.
  4. bogydave
    Yes. good wood
    Will add some "aroma-therapy" to your wood processing :yes:
  5. ansehnlich1
    ansehnlich1
    When I drop a tree, I stand there and look at it, and then I say....well, might as well buck it up, cuz it'll be easier to move.....then once bucked, I say....well, might as well get the tractor and haul it up to the stacks.....then once piled up at the stacks I wind up saying.....hmmm, wonder how this stuff splits, and next thing ya know, I'm stacking the stuff.
    I used to be a wood snob, but no more. I can burn any wood and do, just burn the lightweight stuff when I'm home, or when I don't need a lot of heat, spring, fall, 45 degree day, you know the drill.
  6. yooperdave
    Smells good, huh?
    Post some pics when you burn it so the rest of us can enjoy it too!
  7. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I burn odd ball junk in the fall and spring. i have a few basswood here and sometimes they get whacked when a bigger tree takes wipes them out. It burns.....
  8. MikeInMa
    Ive been cutting some decent sized sassafras lately. Can't beat the scent that rises, and it splits so easily. Toss up between Black Birch and Sassafras, regarding the scents when working with it. Haven't burned any yet. I like hearing how it's good for shoulder burns.
  9. lukem
    Chances are if the woodpeckers are working it then it's probably hollow. Pretty common with sassafras. Be careful dropping it.
    gboutdoors, bang and Backwoods Savage like this.
  10. Backwoods Savage
    Sassafras is worth cutting just so you can enjoy that sweet smell! It is not the best firewood but good for daytime burning and spring/fall burning.
    gboutdoors and amateur cutter like this.
  11. MikeInMa
    I was felling sassafras that was about 10 diameter, low on the trunk. I found that as it fell, that the wood cracked almost like a barber hair. The hinge was more than sufficient. I get the feeling this wood is more brittle than other species. So yeah, be careful felling it.
    Sent from my XT1030 using Tapatalk
  12. MikeInMa
    10 inch diameter, that is.
  13. Spencer
    Spencer
    Seems like it burns alot like poplar to me, short and hot. Worth cutting and splitting for me.
    gboutdoors, Backwoods Savage and bang like this.
  14. fox9988
    fox9988
    NW Arkansas 72717
    The old timers tell me, it was often used for cook stoves back in the day. Medium BTU, easily split to size, readily available, etc.
  15. Backwoods Savage
    Yes it was.
    Also can make for some decent fence posts if you can find some straight ones. Therein lies the big problem with sassy.
    bang, gboutdoors and fox9988 like this.
