Unpleasant phone call from the Electric Company :D
Discussion in 'Chainsaws and Power Equipment' started by Carbine, Dec 29, 2016.
  1. Carbine
    Carbine
    Our house is exclusively electric baseboard heat, and one of my first priorities when we bought this home, was to add a wood forced air furnace. I am guessing here (as the previous owner was on a budget), but I believe we are saving 3-400 dollars a month (maybe more) on our electric bill during these winter months. Efficiently cutting, splitting, and burning large amounts of wood is more of a lifestyle than it is extra work as many of you all know. I have a small fortune invested in equipment, and some blood, sweat, and tears learning the do's and dont's over the last decade or so.
    To make a long story short, the good ol' electric company politely accused me of tampering with the internals of our electric meter here a week or so ago. It was one of those my word vs. their word kind of things. Luckily, I garnished the upper hand- and won this fancy new meter that is going to read the same amount of usage as the last one LOL.
    P.S.- I am still on the hunt for a wood powered air conditioner for next year, so if ya find one... send it my way. :D :D :D
  2. ironpony
    ironpony
    Mid Ohio
    I had a similar experience several years ago, they wound up changing the meter twice.
  3. Eric VW
    Far be it from them to take note of a chimney and stacks o' farwood.....:picard:
  4. Grizzly Adam
    Grizzly Adam Guest
    Had the same issue, with the gas company. We also have a brand new meter and the installer was treated to a gun cleaning show right by a rolling fire in about a 85 degree house.
  5. Carbine
    Carbine
    You would have thought! I told the gal on the phone, not to expect much usage from us. I told her, if the wood furnace isn't running, then we go cold. I'll be putting up a new clothesline in the spring too.
  6. Carbine
    Carbine
    Did your electric bills go up? I've heard from a couple folks that it could go up, which makes no sense to me... Unless my old meter was faulty, which I firmly believe it was not.
  7. basod
    basod
    Mount Cheaha AL
    My utility contacted me about the power bill not long after buying the house(10yo) for the A/C aspect told them I had installed a digital t-stat and less people living in the house, they sent someone out to check it, showed him the lock seal I had cut while residing behind the meter base along with the snake skeleton petrified across the phases.
    After explaining to them if I really wanted to steal electricity I could, but I make it for a living so it all comes full circle back to me they left me alone
  8. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    It would almost be worth it to screw with them for a month. Just run all the electricity that you can heat and everything. Then the following month use absolutely nothing.:D
    Gary
  9. eatonpcat
    No doubt...hahaha!
  10. HDRock
    Take a look at my woodstacks and figure it out, dumb azz!! :picard:
  11. Well Seasoned
    Those "fancy" smart meters are horrible. Keep everyone at least ten feet from them. Cancer causing units (amongst other very bad things i won't mention here) not controlled by the fcc, so radiation, oh well. Look it up!
  12. Naturalgas
    Naturalgas
    Worcester County, Ma.
    You could be at a cheaper rate because of all electric house and with new meter could be new higher no electric heating rate. I've changed many a gas meter because of low use due to new wood and pellet stove installs. Most were after a month or two earlier I put down on low use investigation the use of the new source of heat. They still wanted the meters changed. Those calls were good for at least 2 visits. Job security 101.
    Sent from my iPad using Tapatalk
  13. Eric VW
    I'm gonna look that up.....our meter is on the back corner of our home-right where our bedroom is!:mad:
  14. savemoney
    We have one. It takes a day to get the report of usage on line, but when I look at it, I can tell when we ran the dryer, or crock pot etc.
  15. HDRock
    I got a smart meter not long ago too and it is outside my bedroom, maybe I should put some lead siding out there :hair:
  16. XXL
    XXL
    Ontario, Canada
    I would go the other way and try my dammdest to use less electricity next month and have them really scratching their heads:whistle:
    papadave, clemsonfor, fox9988 and 7 others like this.
  17. Horkn
    Those wood stacks don't grow on their own.
    :loco: :crazy:
    Now those smart Electric meters, Gas. I'll need to look into the bad stuff about them. Our meter I believe it's a smart meter. It's just outside of our BR window, and 4 feet from the bed, where most people spend the highest amount of time.:faint:
  18. Grizzly Adam
    Grizzly Adam Guest
    Not. One. Drop.
    papadave, clemsonfor, Carbine and 6 others like this.
  19. Well Seasoned
    These meters emit a ton of radiation. First generation, power companies across the US said the meters shoot out a signal 4 to 6 times an hour. Radiation that goes with this goes through the roof, way higher allowed on any electronic. Since the power companies aren't controlled by the fcc (maybe by design? ) there are no regulations controlling the radiation. Signals on the 2nd and third generation units emit radiation via signal 4 to 6 times a minute. People are getting cancer, getting tinnitus, etc.
    Secondly, when you come home, power use goes up, and when you go to work, power goes down. Power companies know when your home, when your gone, what your using at what time. Now, strangers or even hackers could know when your gone from your house..... all the guys that used to read the meters are now out of work, replaced by a network.
    You don't want a cancer box attached to your house? No problem, typically you can pay a one time fee of $75 + an additional $10 bucks a month to put the old meter back.
  20. Horkn
    I like the lead shield idea for the SMRT meter. Like all around it. Lol
