I'm new here.
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by jeffneds, Dec 28, 2016.
  1. jeffneds
    jeffneds
    Finland, MN
    I have a cabin heated with an earth stove (smoke dragon). I plan to change it out to a modern stove. The Earth Tove has an 8" flue the new one looks like it will have a 6" flue. My plan is to use a 6" stove flue then transition ay the chimney adaptor to a 6x8" adaptor. The chimney flue is about 15' long and the stove flue would be about 5-6' long. Anybody know if this would create a problem?
    Neds
  2. Well Seasoned
    Should work just fine :)
    Eric VW and papadave like this.
  3. papadave
    Agree with WS, and Welcome aboard!
    What stove are you looking to get? How big is the cabin?
    Well Seasoned and Eric VW like this.
  4. Unicorn1
    Unicorn1
    Amarillo, TX
    Welcome, the Earth Stove is my second favorite wood stove.:)
    Eric VW and Well Seasoned like this.
  5. fox9988
    fox9988
    NW Arkansas 72717
    Welcome jeffneds
    It should draw fine. What's the new stove?
  6. Minnesota Marty
    Minnesota Marty
    Eastern Minnesota
    jeffneds,
    Welcome to the site. I had a garage stove that was a 6" into a 8" chimney. I got my reducer at Fleet Farm. Worked just fine.
    Eric VW and fox9988 like this.
  7. lukem
    With that kind of overall stack height (21') you should be fine. My shop stove has a 6" stove pipe that transitions into a 8" square masonry flue (bigger area than 8" pipe)...probably close to 20' overall...and has all kinds of draft.
    Eric VW likes this.
  8. Matthewchopswood
    Matthewchopswood
    Shenandoah Valley, VA
    In our old house we originally had an Earth Stove with an 8" going into doublewall class A. When I switched stoves I put a 6 inch to 8 inch adaptor on right at the stove. You can see a picture of this in my avatar. With 25 feet of chimney we never had issues with draft.
    Eric VW likes this.
  9. blacksmith
    blacksmith
    central Pa
    Welcome you'll enjoy the site! This is one big family!
  10. My IS heats my home
    My IS heats my home
    Albany, NH
    All I can say is Woodstock Ideal Steel...yup
  11. yooperdave
    And just to let you know, I have an epa stove hooked up the same way.....from a 6" stove to an 8" chimney pipe (class A) and it also works just fine!
    The owners manual recommends that the pipe should remain 6" all the way. Talked to them about this over the phone years ago-no problem.
    Can't argue with success.
