  1. imacman
    imacman
    Denver, NC
    x2!
    ivanhoe, savemoney, CleanFire and 4 others like this.
  2. imacman
    imacman
    Denver, NC
    UNLIKE!!! :mad:
    ivanhoe, CleanFire, slvrblkk and 3 others like this.
  3. imacman
    imacman
    Denver, NC
    That thing STILL isn't fixed? Come on JT, you slacker. Too busy thinkin' of :seasoned: and watching the stat in case of :heidi:
    gbreda, ivanhoe, CleanFire and 5 others like this.
  4. jtakeman
    No likely this watch either!! :eek: o_O
    Winter Storm - Watch from 12/28/2016 11:31:00 AM to 12/30/2016 7:00:00 AM
    Winter Storm Watch issued December 28 at 11:31AM EST until December 30 at 7:00AM EST by NWS AlbanyNorthern Litchfield...WINTER STORM WATCH NOW IN EFFECT FROM THURSDAY MORNING THROUGHFRIDAY MORNING...* LOCATIONS...NORTHERN LITCHFIELD HILLS...NORTHERN AND CENTRALTACONICS...AND WASHINGTON COUNTY.* HAZARD TYPES...HEAVY SN*W.* SN*W ACCUMULATIONS...5 TO 9 INCHES.* TIMING...SN*W WILL DEVELOP THURSDAY MORNING AND CONTINUE INTO THURSDAY EVENING. SN*W WILL TAPER OFF THURSDAY NIGHT.* MAXIMUM SN*WFALL RATES...ONE HALF TO ONE INCH PER HOUR...MAINLYTHURSDAY AFTERNOON INTO THURSDAY EVENING.* IMPACTS...HAZARDOUS DRIVING CONDITIONS DUE TO SN*W COVEREDROADS AND POOR VISIBILITY.* WINDS...SOUTHEAST 5 TO 15 MPH THURSDAY...BECOMING NORTHWEST ANDINCREASING TO 10 TO 20 MPH WITH GUSTS UP TO 30 MPH THURSDAYNIGHT.* TEMPERATURES...IN THE UPPER 20S TO MID 30S.A WINTER STORM WATCH MEANS THERE IS A POTENTIAL FOR SIGNIFICANTSNOW...SLEET...OR ICE ACCUMULATIONS THAT MAY IMPACT TRAVEL.CONTINUE TO MONITOR THE LATEST FORECASTS.
  5. jtakeman
    Though it was until the last storm...... I've had the carb off 2 times now and though it was all set each time. Got some scummies in the tank I guess? Though the POS had an inline filterer thingama jig? Eeent........... :headbang: o_O How it ran all these years without one?? :picard:
    Pulled the carb yet again. Flushed the crap out of the tank and adding a filter this time. I'll be heading down for a filter after a turkey samwich............ Should be good top go now??
    ivanhoe, imacman, savemoney and 5 others like this.
  6. jtakeman
    All fixed! Carb was fine. Seems if you change the fuel filter it gets fuel!! :headbang:
    It had one all along and was full of crap.............. o_O Coarse dummy me needs to tear off the carb and see its perfectly clean and no fuel in the bowl. :bug: Open the shutoff and no fuel comes out of the line. Pull the tank and look whats there. Whoops.
    Dumb azz! :picard:Always in a rush, Helps when ya stop and think. :whistle:
    :cheers:
    gbreda, ivanhoe, Pete Zahria and 7 others like this.
  7. will711
    will711
    Pocono Mts.
    Steve and I did lunch today at my favorite watering hole :thumbs: and he brought me a little Holiday Cheer , thanks my brother :cheers:
    ttdberg, gbreda, ivanhoe and 8 others like this.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Anytime Brother!
    ttdberg, gbreda, ivanhoe and 5 others like this.
  9. bogieb
    I'm in the 6-12" range. But it also depends on where that line ends up being. It is possible for me to end up in the 5-10". Either way I'm going to be snow blowing.
  10. bogieb
    I wasn't visiting this morning because I had chit to do and left before 8 am for my dentist appointment. Stopped by L*wes first, then dentist, then HD/Target/BB&B and Irving (I was starving by then so got a couple of cheddar dogs). Then to Agway and TSC for bird and wildlife food, filled up the truck with gas. When I got home unloaded all the stuff I'd gotten from the BBS's and farm stores. Then I moved the ton of Inferno's out of the shed and into the basement. Used the Explorer so it only took two trips :D. Did laundry (wash/dry/fold), fed the wild birds and squirrels, gave the kitties treats, the dishes are currently being washed and gotta go to my night job here pretty soon.
  11. will711
    will711
    Pocono Mts.
    Did ya take a breath after all that , I believe I burned 500 calories just reading that :D which means I can have more Beer:cheers:
    gbreda, ivanhoe, Earl764 and 9 others like this.
  12. bogieb
    Well, I am sitting here reading the forum for a couple of minutes.
    ivanhoe, jtakeman, imacman and 5 others like this.
  13. artc
    artc
    Rocky Hill, CT
    now there's a balanced breakfast!:zip::zip:
    bogieb, gbreda, ivanhoe and 8 others like this.
  14. CleanFire
    CleanFire
    Looks like ground zero here according to the weatherfolks. :picard:
    We're gonna get blasted here on the mountain.. Calling for 12"+ here .. But I got another snowblower. :thumbs:
    Stopped by Home Depot last night to pickup some T-50 staples, saw a Toro Power Max 724 OE on the floor marked down 25% ($599 vs. $799), a customer return, asked about it - was told "there are actually some people who don't know how to add gas to a snowblower" .. Near as I can tell, PO thought the oil fill was fuel fill, I pulled the oil dipstick - the crankcase still smelled like fuel. :picard:
    But since they weren't able to start it, the HD folks drained it / tested it / put it on the floor / and it still carries the (new) full 3 yr. warranty, I figured WTH, it was one of the models I was looking at back in November.
    We picked it up today: added fresh oil at the store, threw in some fuel, started 2nd pull, auger worked fine, motor sounds fine, drive train working as new, put it in gear and backed it up onto the utility trailer.. And off we went.
    Ran it for about 10 mins. after getting home, checked the oil, just a faint fuel smell. I'll change the oil out for fresh in the a.m., before the snow starts to fly.
    We'll see how it throws snow tomorrow, will snap a pic or two. :yes:
    bogieb, gbreda, ivanhoe and 5 others like this.
  15. imacman
    imacman
    Denver, NC
    LIKE!!!!! :thumbs::drunk::cheers:
    ivanhoe, savemoney, jtakeman and 3 others like this.
  16. imacman
    imacman
    Denver, NC
    As always, check the simplest things first. :headbang:
    bogieb, gbreda, ivanhoe and 6 others like this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
    :popcorn: :D
    Good luck, I hope you don't get as much as they say.
  18. imacman
    imacman
    Denver, NC
    :doh:
    Since these things only use a qt or so of oil, I've been putting full synthetic 0w or 5w -30 in mine. Makes it easier to start on those really cold days.
    bogieb, gbreda, ivanhoe and 4 others like this.
  19. CleanFire
    CleanFire
    Thanks Steve, but I'm raring to try this expensive toy out ! :thumbs:
    Doing the Skeeter here - Bring on the Sn*w baby ! :rofl: :lol:
    :banana::banana::banana:
    :cheers:
    Yep, 17 oz. to fill the small (6.5 HP equivalent) crankcase on the motor. :loco: :crazy: (2 glugs from the jug, and it was full @ HD.)
    Got 5w - 30 semi-synth in it now ('cause it's all I had on the shelf this am), / for tomorrow's oil change & fun, but I'm going to pickup some full synth on Friday, and treat 'er right. :yes:
    bogieb, ivanhoe, will711 and 4 others like this.
  20. slvrblkk
    slvrblkk
    Northampton, PA
    You are a sick, sick man! :rofl: :lol:
    gbreda, ivanhoe, will711 and 7 others like this.
