Improving draft
Discussion in 'Modern EPA Stoves and Fireplaces' started by Sawdog, Dec 18, 2016.
  1. Sawdog
    Sawdog
    I have an outdoor boiler and I want to improve the draft in the stack. When I open the door to load, I get quit a bit of smoke back at me and want to see what I can do to make that better. The system itself is fan assisted when the system calls for heat, so it's not necessarily a performance issue although there are many benefits to improving the draft.
    Now, I know there is a lot that goes in to what creates draft within a system, but about the only thing I can change is stack height. Stack is 8". I currently have about 7' of pipe above the boiler. I'm wondering if someone has a way of calculating how much stack I actually need to make a difference.
    My assumption is that a little should go a long way just given percentages. If I add 3' to an already 7' stack, I'm adding 43% to the overall height. But, id rather not be spending $100-$200 on insulated sections when the actual difference won't be enough to justify the expense. Make sense?
    Can anyone offer any advise?
    Eric VW and Backwoods Savage like this.
  2. Horkn
    For an outdoor wood boiler, why would you care about smoke upon reloading from the door?
    But even so, you shouldn't need double wall if you want to extend the height.
    SKEETER McCLUSKEY and Eric VW like this.
  3. Sawdog
    Sawdog
    Increasing draft has a lot of be benefits, with one being less smoke from the door after opening. I agree that since it's a boiler, it's less of an issue, but I'd still like to increase the draft if I could. Loading can be difficult at times, especially when you don't want to smell like smoke the rest of the day. Better overall combustion is another concern.
  4. saskwoodburner
    saskwoodburner
    Eric VW, Backwoods Savage and Horkn like this.
  5. Highbeam
    Highbeam
    Can you just use cheap single wall pipe? At least for testing? Nice not to have to worry about chimney fires. Taller flue might also carry the acrid smoke farther away before it gets down to eye level.
  6. Backwoods Savage
    Yes, use single wall pipe to test before buying insulated pipe. No doubt it will make a difference but will it make enough? I'd think with this type of stove you will still get smoke when you open the firebox door so you will still have to continue to crack the door, wait a bit then open it.
    The extra pipe won't make a big difference in the burn because of the design but it might get the smoke higher so that might not be such a problem. But, it is worth experimenting.
    One thing I don't understand is why so many OWB have no cap. They don't even cover the chimney in summer to keep water out.
    Thor, Horkn and Eric VW like this.
  7. Boomstick
    Boomstick Banned
    Saratoga county ny
    I say you redneck engineer it.
    Just buy and add one peice of pipe at a time untill desired effect is reached!
    Horkn, SKEETER McCLUSKEY and Eric VW like this.
  8. yooperdave
    Definitely use a test pipe, single wall before a purchase of $100 or more.
    I don't know why you want to improve the draft; just for reloading purposes?
    Backwoods Savage I always cover my stack during the period it is not in use....but I never cover the masonry chimney on the house
  9. Eric VW
    What's wrong with you?!:hair:
    FWIW, I don't either....just like to poke atcha :yes:
    As far as draft, extending the length of the chimley allows for a larger difference in temps between the firebox and the top of the flue (greater delta T), so it should make a difference, yes?
  10. yooperdave
    I'm with the school of thought that the stronger the draft, the quicker the burn.
    Feel the burn yet?
  11. Eric VW
    Agreed....
    Thor, Horkn and yooperdave like this.
  12. Sawdog
    Sawdog
    4 OWB's around me and we all have caps.
    Thor, Backwoods Savage, Horkn and 2 others like this.
  13. Horkn
    Yes, it will increase the amount that it will burn, and depending on the boiler, they already go through a lot of wood.
    Thor, Backwoods Savage and Eric VW like this.
  14. bushpilot
    bushpilot
    Eastern Washington
    Since it is fan assisted, is there a way to add an override switch to run the fan while loading? Better yet, use a timer so that you won't forget to turn the override off.
    Excuse my suggestion if it is ignorant, I don't know anything about OWBs.
    Thor and Backwoods Savage like this.
  15. Sawdog
    Sawdog
    Not ignorant. The fan is located in the door so that's not possible.
  16. bushpilot
    bushpilot
    Eastern Washington
  17. Eric VW
    Thor, Backwoods Savage and bushpilot like this.
  18. bushpilot
    bushpilot
    Eastern Washington
    It seems like we could add a mousetrap in here somewhere ...
  19. yooperdave
    Maybe a pre-dryer for the wood?
    :D
  20. Eric VW
    Other than 2-3 years?
