Used pump for moving waste motor oil
Discussion in 'Hobbies and Interests' started by Unicorn1, Dec 18, 2016.
  1. Unicorn1
    Unicorn1
    Amarillo, TX
    I have a 300 gallon waste motor oil tote on the side of the shop. I'm always thinking about a waste oil furnace although the Fisher stove works very well. It would be a nice secondary heat source if I leased the entire 40x60 building and not just half.
    A friend in the oil business came by and asked if I could use this set up, well sure I'll give it a go.:)
    I can't sleep sometimes with all ideas rolling around in my gray matter.
  2. TurboDiesel
    I've heard used oils need filtered and are still problematic in used oil furnaces
  3. bocefus78
    bocefus78
    Great score!
  4. brenndatomu
    Dad used to heat his shop with a furnace that was designed to use straight drain oil...and we did, right out of the drain pan sometimes. Worked great!
    I wonder what ever happened to that thing?
  5. Unicorn1
    Unicorn1
    Amarillo, TX
    Yes this oil will need to be filtered, the pump would transfer it to another container higher up in the shop for gravity filtering.
  6. shaggy wood dump hoarder
    menomonie
    :popcorn:
    I've been thinking about making a waste oil burner but idk where I'd put it
  7. KsKent
    KsKent
    NE Kansas
    Or you could just use it for bar oil! UH OH!!!!! I hope I don't anything stated here.
  8. Unicorn1
    Unicorn1
    Amarillo, TX
    Here's a guy on another forum that converts oil furnaces to burn waste motor oil
    This requires filtered oil and better yet if its gone through a centrifuge. A costly turn key commercial waste oil furnace would only need minimal filtering but cost $5K plus.
    I really want a centrifuge because I like to clean stuff. :)
    TurboDiesel likes this.
