Alaskan mill
Discussion in 'The Sawyer Room' started by Blackop555, Dec 16, 2016.
  1. Blackop555
    Blackop555
    U.P mi
    I apparently am an idiot. Made a alaskan mill I cut two slabs and now I can't cut anymore. It goes in half an inch and stops. It's 30 inch sugar maple. I tried a ripping chain and regular. Is there a specific grind angle on chain to help? I have to push all my might on chain to cut the two that I did
    Woodsnwoods and Jack Straw like this.
  2. mdavlee
    mdavlee
    More rakers depth is needed
    Woodsnwoods likes this.
  3. Blackop555
    Blackop555
    U.P mi
    I will try that tomorrow:coldfire:
  4. mdavlee
    mdavlee
    You can sharpen the chains with more aggressive angles to feed itself also. If I have to push I sharpen. I try to keep it where all I have to do is hold the trigger on the saw.
    Woodsnwoods and thistle like this.
  5. The Wood Wolverine
    Can you post a picture of your cutters/teeth? If your piece is laying flat, you'll have to push. I think what Mike is referring to is having one end slightly elevated, allowing the mill to flow downhill.
    Woodsnwoods and mdavlee like this.
  6. Blackop555
    Blackop555
    U.P mi
    I reground tilt 60 and table at 10 degrees them really took the rakers down went better then I thought smoother too. FB_IMG_1482003050105.jpg
