Catalpa - you know, that green bean tree
Discussion in 'The Wood Pile' started by MikeInMa, Dec 15, 2016.
  1. MikeInMa
    Does anyone have first hand experience with this type of wood?
    I have three pretty big trees to cut down and it's all mine.
    I know that free wood is good wood, but is it worth taking and aging?
    I found it on the BTU chart, and it's about in the middle. Better than some, not a good as others.
    I appreciate any 1str hand experience.. cutting, splitting...etc.
    I'd have searched the forums to find any prior postings, but darned if I could find a search option here. there' got to be one, right?
    Horkn, Hellcat, Eric VW and 1 other person like this.
  2. Grizzly Adam
    Grizzly Adam Guest
    Search is at the top right, right below your name. Depending on screen size, it may just show as a magnifying glass. Catalpa used to be used for furniture, abd i think even as a tone wood.
    Hellcat, Eric VW and Backwoods Savage like this.
  3. cnice_37
    cnice_37
    Search is top right under your uname/ Inbox/ Alerts
    Haven't burned it, have handled it, posted up some big chunks in the milling forum here. It beats white pine on the BTU chart and the whole buncha messy chart.... and I take and burn that so my vote is yes.
  4. MikeInMa
    Found it - thanks Grizzly and cnice
  5. CTYank
    CTYank
    CT Panhandle
    Catalpa retains HUGE amounts of moisture, which obviously has to be encouraged to leave before going into a stove.
  6. Scotty Overkill
    Catalpa is a lot like poplar IMO. Yes it's a waterhogging wood, but once C/S/S, it seasons quickly and puts out very good heat. It doesn't last real long in the stove, but if you're needing wood, it's worth using......
  7. nobody
    nobody
    Ok
    Around here they have worms that eat the leaves. People let them eat the leaves so they have fishing bait readily available.
    Horkn, Hellcat, MikeInMa and 2 others like this.
  8. MikeInMa
    The trees were "girdled' last year. so, if I can get them down over the next few weeks. I'll be ahead of the game regarding drying out/seasoning.
    Horkn, Hellcat, Eric VW and 2 others like this.
  9. Grizzly Adam
    Grizzly Adam Guest
    In the south it is often called the catfish bait tree. The worms are actuakky caterpillars and supposedly dine exclusively on the catalpa's giant leaves.
  10. ansehnlich1
    ansehnlich1
    I've burned it. I wouldn't make it a priority over some other stuff, but wouldn't walk past it either. I used to be a wood snob, no more.....I find a purpose for all the species that grow around here. It makes for good bowl turning.
    Fanatical1, Horkn, Hellcat and 4 others like this.
  11. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    If you need it take it. If not I'd let it go. You'll get more heat cutting, splitting and stacking if than burning it.
    They use to make railroad ties out of it back in the day. Mostly because the trees grew so big around and the wood wasn't much good for anything else. Soak almost anything in boiling creosote and it will be tough and last a long time.
  12. Horkn
    I've burned it. It kinda sucks for firewood. Granted, I'm a bit spoiled with all the gear tree varieties here.
    I bought a dump truck load of it years ago, and it was dry, but still crappy. It burns fast, and doesn't have a lot of btu's.
    Ashwatcher and Backwoods Savage like this.
