I cut, therefore....
Discussion in 'The Wood Pile' started by MikeInMa, Dec 11, 2016.
  1. MikeInMa
    ....I split and stack!
  2. yooperdave
  3. MikeInMa
    First time using the cinder block racks. I had the blocks, just needed the 2x4's.
    I bumped them right up against existing racks, so I only needed the 2x4 uprights, on one end.
    Those are compost bins you can see to the side.
  4. NYCountry
    NYCountry
    Mohegan Lake NY
    As long as it's off the ground it works. Nice way to use those cinder blocks
  5. Lone_Gun
    Lone_Gun
    Washington
    I've seen several using the cinder blocks, I'm curious how high you can stack with them safely?
    LG
    Sent from my iPad using Tapatalk
  6. Backwoods Savage
    I like your cart. We have one that is probably a bit older than yours. I think we got this one back in the 70's. It is still in great shape and has been used a lot. I have thought about putting a covering on the handle like yours but so far has only been a thought. I'm thinking something like the stuff you can get to dip wrench handles in to coat them. Might not be so cold to hang on to in winter.
  7. MikeInMa
    Me too! I guess I'll be finding out.
    You can see my older racks. I usually stack wood on them about 4.5 high, watching the "Wobble Factor", as I get it that high.
    The cinder blocks, are a split or two higher to start with, as you can see above. I'm thinking that the"WF" should be about the same, measuring up from the horizontal 2x4's.
    I'm sure others that have been using cinder blocks, will chime in. I will, when I get them stacked higher.
  8. MikeInMa
    I've had good luck with that cart. I've had it since the late 80's, and it's still in prime condition. It's kept inside, when not in use, so that helps.
    The handle is a dense foam material that it came with. Other than an occasional re-tightening of screws and air pressure, it just keeps a-rolling.
  9. Horkn
  10. Eric VW
    Great racks make great stacks MikeInMa :stacke: :woodsign:
    Looks real nice, sir- x2 on that cart-I likey :yes:
  11. MikeInMa
    OK - So, I'm sold on the cinder block racks.
    I have about as much wood stacked(for 2018/19) on the cinder block rack as my others.
    No issue with excess wobble.
    I have other cinder blocks. Will be getting some more 2x4x8 PT shortly.
    Scotty Overkill and Eric VW like this.
  12. Scotty Overkill
    Looking good!
  13. Canadian border VT
    got the same cart.. was my grandfather's I remember it from 70s.. I like it because it's not tippy!
    Backwoods Savage for the short term 1/2 inch water pipe insulators (foam) work for handle.. don't last long but they are only a couple of dollars.. til you get around to doing it right
  14. Backwoods Savage
    Funny as I had thought about using some of those and I have some laying around somewhere. I should do it because it is mostly the ornery one who uses the cart.
  15. MikeInMa
    Not tippy at all. But, ya need to take care loading/unloading. It'll tip forward if not aware of weight/ balance. Highly recommended over standard wheelbarrow. Over the years, I'd guesstimate >150 cords moved in that. Care for your tools, and they'll care for you.
    Sent from my XT1030 using Tapatalk
