Drain saws or no?
Discussion in 'Chainsaws and Power Equipment' started by g60gti, Dec 7, 2016.
  1. bogydave
    2 cycles, empty & run dry
    The rest
    Shut fuel valves & run dry
    Run Dry & add fres gas to any left in the tank in spring before starting
    I also
    Disconnect batteries, store in heated garage, give them a charge couple times thru winter
    Andyshine77, Joe Seaton, Thor and 2 others like this.
  2. CNE deer
    CNE deer
    ohio
    +1
  3. mdavlee
    mdavlee
    I like to run the pump gas out and put some VP or tru fuel in and run til it's went through the carb good and then shut off and store. 2 stroke or 4 stroke either one. I usually mix klotz original techniplate with the gas for the 2 strokes.
    Thor, Flatlander Pete and Leadfarmer like this.
  4. Woodporn
    Woodporn
    S. MA
    Come again??????????
    Mag Craft, Thor and Flatlander Pete like this.
