GCI60 Blower Noise
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Skier76, Oct 11, 2016.
  1. Skier76
    Skier76
    CT and SoVT
    Fired the stove up for the first time in months last night. Gave it a good cleaning first, so it was ready to go.
    I noticed last season that the blower(the one that blows the air int the room) would make some noise when it initially came on after the stove had been off. It's hard to describe the noise. Almost like a chirp/grind/squeak. It's not that loud and goes away after time; say 10 minutes or so. This is the third season with the stove. Is there a way to lube the bearings or the motor on the blower?
    IHATEPROPANE and ivanhoe like this.
  2. badbob
    badbob
    Your blower should be a tangential blower,possibly high quality,probably german.The motor may have bushings or bearings.However,at other end of the long wheel/cage,is a rubber mounted bushing or bearing.If it is a bushing,it should be lubed every year,2 times under heavy use.You need to remove unit and inspect.
  3. imacman
    imacman
    Denver, NC
    Skier76 Does it look like one of these? If so, 3 in 1 oil Blue Can (or reg. in a pinch)....2-3 drops in each port. They may be on the underside, which means removing the blower & motor to oil. You could also take it apart & rotate motor so ports are on top for easy service in the future.
    They should get lubed every 1 1/2 months or so under constant use.
  4. wildwest
    :salute:
  5. Skier76
    Skier76
    CT and SoVT
    imacman,
    Looks like this: Regency GC60 Convection Blower 80MM - GC60-037 It's the convection blower. I don't have a pic of my stove right now, but I know it looks just like the one in the link.
    Thanks for those pics! I'll be sure to lube the exhaust blower motor now that I have the oil points that you posted.
  6. jtakeman
    Dang, That's an expensive blower!! Motor looks to be sealed, But I imagine you can get lube into the support bushing on the far end??
    Hopefully it has an oil port on the motor.
  7. Skier76
    Skier76
    CT and SoVT
    That's what I'm hoping. Maybe that cap on the other side comes off. I'll have to look.
    Very pricey! That was one of the lower prices. Another site was $400+
    IHATEPROPANE, ivanhoe and jtakeman like this.
  8. jtakeman
    :eek:
  9. imacman
    imacman
    Denver, NC
    A great majority of the motors used for the exhaust are ball bearing types, and don't call for any lubing. That being said, many of us try to still "sneak" some oil around & behind the seals anyway.
    IHATEPROPANE, Skier76 and ivanhoe like this.
  10. badbob
    badbob
  11. Skier76
    Skier76
    CT and SoVT
    Great input guys! Thanks a bunch.
    A $20 bushing is a lot better than a whole new fan. I hope to pull the stove out this weekend to investigate. If it is the bushing, can that be lubricated or will that just attract dust?
  12. imacman
    imacman
    Denver, NC
    IMO, I'd try giving it a few (2-3) drops of light oil like 3 in 1....can't really hurt, and may solve your problem.
    If the noise stops, or gets less, at least you'll know that's the problem. If it solves the problem, I'd keep lubing it every 1 1/2 months or so, or if the noise returns. When the oil stops working, then spring for the bushing.
  13. Skier76
    Skier76
    CT and SoVT
    Sounds like a good plan! I didn't get a chance to pull the stove this weekend. And probably won't run it this week. 80's predicted. 80's! Seriously? Ugh.
  14. Skier76
    Skier76
    CT and SoVT
    I had the stove out last night...but was too busy to check here.
    It looks like it's the end bushing after all. I spun the fan by hand and heard it breifly. I'll see if I can get a little 3-1 oil on there. It's pretty far down where the bracket mounts. May have to use some plastic tubing or a straw to reach it.
    imacman, IHATEPROPANE and ivanhoe like this.
  15. badbob
    badbob
    Do not think oil will fix this this late in the game.
  16. Skier76
    Skier76
    CT and SoVT
    That may be the case. Thankfully, the noise only happens briefly when the fan starts up. Running, you don't hear anything.
    It's possible that I'm just over analyzing it.....
    imacman likes this.
