Plumbing
Discussion in 'The DIY Room' started by thewoodlands, Dec 1, 2016.
  1. thewoodlands
    thewoodlands
    Ok, why can't I get B threaded on to A? :hair:
    Well Seasoned and Eric VW like this.
  2. Bret Hart
    Bret Hart
    Central NY
    Try sliding the nut off of the elbow and see if the threads will start. Maybe the threads are boogered up?
    Stihl Livin and Well Seasoned like this.
  3. thewoodlands
    thewoodlands
    It goes on off the elbow.
    Well Seasoned likes this.
  4. papadave
    I think you've got the wrong plastic.....uh, gasket, or whatever those are called. Isn't that supposed to be flat?
  5. Grizzly Adam
    Grizzly Adam Guest
    Yep, that type of gasket is for the an unflanged pipe.
    Well Seasoned, papadave and Eric VW like this.
  6. thewoodlands
    thewoodlands
  7. Grizzly Adam
    Grizzly Adam Guest
    They also make flat rubber ones, usually in orange that should work.
  8. thewoodlands
    thewoodlands
    The crazy thing was that same type of washer was on that pipe, maybe that's why the nut cracked.
  9. Eric VW
    Very astute, sir!:handshake:
    You were a plumber in your previous life, yes?:rofl: :lol:
  10. papadave
    Let me clear. I've done plumbing.
    Let me be clear again.......I HATE PLUMBING......except Sharkbites and Pex. Genius.
  11. Eric VW
    Do love me some PEX!:thumbs:
    :handshake:
  12. thewoodlands
    thewoodlands
    I had it done by 8:40 this morning but we had a small leak so I snugged it up tighter and everything is good.
    papadave and TurboDiesel like this.
  13. TurboDiesel
    See?!? Who needs a plumber?!?:whistle:
    papadave likes this.
  14. TurboDiesel
    :BrianK: Heresy!!!
  15. Grizzly Adam
    Grizzly Adam Guest
    I love PEX when I get called into work for a leak!
    TurboDiesel and papadave like this.
  16. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    thewoodlands get the Teflon tape off of the tailpiece. it will only ruin your day later. you need the flat tire shaped washer on the end.
    as far as shark bites, terrible idea. get the right parts and do it right. per is great, but that's with the brass fittings, that's abs stuff is junk.
    Stihl Livin and TurboDiesel like this.
  17. papadave
    Nope.
    We thought that too, until we used it. No runs, no leaks, no errors, and tons less time. Piped a whole new construction basement not too long ago in about 4 hours. Try that with copper.
    Come on into the 21st century, the Pex is fine. :dex::rofl: :lol:
    TurboDiesel likes this.
  18. TurboDiesel
    I do little to no household plumbing, so pex is not my thing. I have done tons of schedule 80 pvc. up to 20" though
    Put this piece in with a crane:dex:
    I was surprised. a 20" 90 is only $1200
    :faint:
  19. papadave
    Whoa baby. Now THAT'S some plumbing.
    I like the rigging to pull it together.
    basod and TurboDiesel like this.
  20. TurboDiesel
    You only get one chance
    will711, basod and papadave like this.
