Still Ain't Been Cold
Discussion in 'The Wood Pile' started by MightyWhitey, Nov 27, 2016.
  1. MightyWhitey
    MightyWhitey
    Here in the northern "The Peoples Republic of Illinoiz" yet!! Granted; we've had 'overnights" in the mid to upper 20's......................but, it's not been COLD......................yet.
    Just enough for a load or 2 a day so far.
    Just saying.................
  2. NortheastAl
    NortheastAl
    Putnam County NY
    Same here. This morning I had cold lock and filled the house with smoke. Need to keep a warm stove and house to avoid this. Second time this season it's happened. Once we can burn 24/7 we'll be good to go.
  3. Hellcat
    Hellcat
    Centre Hall, PA
    Fortunately I don't have a problem with smokey start up with a pretty tall 7 inch stainless steel flu but a guy I work with does and he said he leaves his stove door open for half an hour or so before light up and the warmer inside air warms his flu enough to prevent house from getting smoked up. Don't know if this would work for you, might be worth a try.
  4. Star Gazer
    Star Gazer
    Right behind you
    Maybe try this. Load the stove as you normally would. Then put a few pieces of kindling on top. You can light the bottom, and the top. The top kindling will preheat the chimney while the bottom will light the rest of the wood and will decrease your startup time. I tend to use this during the shoulder season. Generally I can have the stove top up to 500 degrees in about 10 minutes. :) :fire:
    And, if you have a sluggish fire, add some kindling to the top!
  5. Star Gazer
    Star Gazer
    Right behind you
    Same here only most nights are in the mid 30's and have had some in the mid 40's. Enough to make the house cold enough for a single fire, and a small one at that. There have been a few nights with the overnight temperature in the low 20's, and during the day maybe 42 with winds in excess of 60mph, but even then, just a few fires, but all cold starts! :wacky:
    NortheastAl and Backwoods Savage like this.
  6. J. Dirt
    J. Dirt
    I know where the cold is!!!!!
    It's in my head!:shiver::sleeping: Been there terrible since last Wednesday great way to spend thanksgiving and haven't even felt up to splitting or cutting
  7. Brett
    Brett
    Northwest Illinois
    Hate it when I do that...but yes it happens. Sometimes I avoided this by opening a window facing toward the blowing breeze. Pressurizes the house a little and forces a draw in the chimney.
  8. Brett
    Brett
    Northwest Illinois
    You are from my neck of the woods!
  9. Backwoods Savage
    Hey Whitey, we have to remember that it is only November. Still a month away from the really cold....I hope.
    Star Gazer and NortheastAl like this.
  10. red oak
    red oak
    No real cold to speak of here outside of a day or two. Still burning chunks, uglies, pine, sycamore, and woodworking scraps that I want to get rid of. No need to dip into the 3 year red oak yet!
  11. JustWood
    JustWood Guest
    Same here. Pizzn mehoff !
    I'm late to the game getting ready for winter. Don't need this head cold slowing me down.
  12. NortheastAl
    NortheastAl
    Putnam County NY
    Thanks. I think it was because the house was cold at 62° and I just threw in the wood and set a SuperCedar in there and lit it. I might try leaving the door open till I feel some updraft.
    Star Gazer and Backwoods Savage like this.
  13. NortheastAl
    NortheastAl
    Putnam County NY
    Sounds like this might be a good idea as I had to throw a SuperCedar on top of the splits to get the heat up. After a couple minutes it did work.
    Backwoods Savage and Star Gazer like this.
  14. Backwoods Savage
    That could help. Twice now I've started a fire when the temperature was not down that far so I let a half of a super cedar in the flue. With our stove, the flue goes out the rear so it is easy to set something in there and light it off. This is enough to warm up the flue and get a draft started. I've done it in the past with newspapers too.
  15. NortheastAl
    NortheastAl
    Putnam County NY
    My son has used a propane torch to warm the air in the box. I guess in a pinch it ain't a bad idea.
  16. Mag Craft
    Well it has been cold here. The high today was 27* with a pretty brisk wind. I came down with a flu bug so have not been out side in 4 days. Finally starting to feel a little better now.
  17. Thor
    Thor
    Genoa City,Wi
    Can't like the flu bug, but glad to here your beating it!
  18. Locust Post
    Ouch
  19. bogydave
    FYI
    Polar vortex is forming
  20. Jeffrey Svoboda
    Jeffrey Svoboda
    bogydave man its hard to like those numbers. I know most of us here look forward to the cold but that's a little much. Sure wish I could send you a big arm full of oak or hickory. Stay warm!!!!
    Chvymn99, Hellcat, Thor and 1 other person like this.
