Wood Burning Inserts Large
Discussion in 'Modern EPA Stoves and Fireplaces' started by Melanie, Nov 23, 2016.
  1. Melanie
    Melanie
    Does anyone have a large flush mount wood burning fireplace insert they can recommend? Information & reviews are limited in this area. I currently have a PE Vista wood stove which is fantastic, but would like to use the fireplace for more of an additional heat source. The configuration is such that a freestanding stove would not work. I'd prefer non-catalytic, quiet blower... any input is appreciated.
  2. papadave
  3. Melanie
    Melanie
    Thank you papa Dave, good to be here too. I've searched high and low..
    Eric VW and Horkn like this.
  4. papadave
  5. Horkn
    Quadrafire makes great inserts, some are flush, and other like my Quadrafire 4100i are a bay window. Their fans are quiet, and variable, and can automatically turn on and off when temps in the stove gets to those temps.
    I put mine in myself last early December, and it's turned into my primary heat source. I live pretty far north so that's a good measure of its efficiency.
    papadave, Eric VW and Melanie like this.
  6. Melanie
    Melanie
    Thanks for your input. I looked at a Quadra fire today and determined the larger flush model, may work. Info states burn times up to 14 hrs. WOW if this is even close I'll be happy.
    papadave, Eric VW and Horkn like this.
  7. Melanie
    Melanie
    Wow that was am amazing DIY! Sure was beautiful. Thank you for sending me to the thread.
  8. Horkn
    I think you're talking about the Voyager grand. It's impressive I can tell you. I was looking at one, until I came across a barely used Quadrafire 4100i with a SS liner for 350. Yeah, that was a steal.
    The other one I was looking at was the Vermont Castings Merrimack. That company has gone through some big changes recently and owners of VC have said that they wouldn't buy one until these concerns are taken care of.
    I'm very happy I didn't get a bigger insert. The 4100 will get this 1700 sq ft open concept ranch warm quickly. I've also been working further ahead on my firewood, so while I'm not at the 3+ yr plan, I've got slightly better seasoned wood than I did last year. Also I've got a season of burning in this insert and that goes a long way too.
  9. Melanie
    Melanie
    The 4100 sounds like the best choice for you. Boy what a steal. Seasoned wood really helps put the heat out too.
    I'll be heating 2200 sq. Ft. 1 1/2 story cabin. I have a Wood stove in my dining room, and it does very well. But doesn't heat the whole house when the Temps get below 20 or its windy.
    I hate to cover my fireplace arch! Maybe find a metal fab guy to custom a face plate??? After 15 years I'm convinced an insert would be a good thing. 20161120_194649.jpg
    Chaz, Ashwatcher, NYCountry and 4 others like this.
  10. Melanie
    Melanie
    Yes the voyageur grand is correct. Thanks for the photo. I'll also check out the Vermont Casting, as I'm in no hurry.
    Canadian border VT, Horkn and Eric VW like this.
  11. Eric VW
    Welcome to the best gang of farwood hoarders around Melanie!!!
    Can't wit to see what you come up with!
    Horkn and Melanie like this.
  12. Horkn
    Melanie, what are the dimensions of the fireplace opening?
    Yes, the surround costs extra anyway, so you might as well have one fabbed up to really complement your stonework.
    Melanie likes this.
  13. Locust Post
    Welcome Melanie, that is a beautiful fireplace. Here is my Buck Stove 91, of course though it is a cat stove. I think the 80 in the Buck is a good one if you like non cat (I did not check that model might be 81). The brother to mine in the non cat is the 94 which is a non cat that is relatively new to Buck's line up and I read some mixed reviews but I also knew I wanted a cat stove. It comes with flush surrounds but I had to customize for my application. deco 002.jpg
    Melanie likes this.
  14. Melanie
    Melanie
    Thanks. I like your Buck too.
    I just don't want the maintenance of a cat. & am comfortable with fire wash. I'll look at a Buck also. I would like a work horse, that burns all night! Good wood helps... and larger pieces in addition. So a big firebox would help.
    Horkn and Locust Post like this.
  15. Melanie
    Melanie
    Horkn-Width 35" front & 27" back, height 25" onsides & 27" center, depth 28.5",
    Hearth 18", 52" clearance to mantel...
    Horkn likes this.
  16. Melanie
    Melanie
    Non-catalytic
    Buck Model 74 ZC Wood Stove
    According to the dimensions it may be too large, unless that is the face frame listed. But it looks like a work horse.
    Horkn likes this.
  17. Locust Post
    [​IMG]Model 85 looks like it would fit
  18. Locust Post
  19. Melanie
    Melanie
    OK guys anyone know about a lopi I think freedom model insert? I found one 4sale on a market site!!! The guy isn't for sure what midel, but it looks like a freedom. $300 it's a steal if in good shape. Any suggestions onwhat to look for or ask are much appreciated. Do you think money wise used would be a wise choice to start out? & if Iwant to invest later on a new insert I can spend that 3000+ grand to get the look Iwant flush, huge view glass, custom arch....I wanted to upload a pic. Maybe tomorrow.
    Horkn likes this.
  20. brenndatomu
    I have a arched stone FP too. I recently installed a Drolet insert but will not be installing the surround cover...it would look terrible IMO. I made legs for the insert to make it look more stove like...and get it up off the floor for loading. Pics here Fire in the hole!
    Also, I will be having some sheet metal water jet cut into a woods or nature scene to fit between the top of my stove and the FP arch...just to cover up the pipe and make it look more "finished"
