Getting close to 3 years ahead now what?
Discussion in 'The Wood Pile' started by DNH, Nov 11, 2016.
  1. DNH
    DNH
    Missouri
    This is red oak and walnut cut in a logging operation about 2-3 years ago, the outside is a little soft I'll get it CSS soon. Will it last 2-4 years if top covered or should I plan on burning it before then? That's a 16' trailer it's setting on.
  2. NortheastAl
    NortheastAl
    Putnam County NY
    Once you hit three years, just keep on goin'!
  3. blacksmith
    blacksmith
    central Pa
    Go for 6!:salute::whistle::bug::hair::woodsign::stacke::axe::tree:
  4. TurboDiesel
    Getting close to 3 years ahead, now what?
    Just a little more!!
  5. papadave
    Go ahead and actually get to 3 years ahead, then we'll talk. :thumbs:
    I'm still working on that myself.......again.
  6. GrJfer
    GrJfer
    The Woods of Arkansas
    Being At 3 years ahead I now Just cut to replace what I Use. If I get beyond that point I sell a little.
  7. bogydave
    CSS'd , off the ground & Top covered, it should last a long long time.
    Nice to be way ahead , eh?
  8. Backwoods Savage
    Will it last? I doubt it will last more than 10-15 years once you get it split, stacked and top covered. :thumbs: Worry not about that outside being a little soft as that is normal with oak.
    Only thing better than close to 3 years ahead is to be 3 years ahead! Then keep on cutting but a little slower now and that can be sweet.
  9. NH mountain man
    NH mountain man
    WMNF N.H.
    I gotten tons of Oak like that over the years it will be fine with top covering.
  10. fox9988
    fox9988
    NW Arkansas 72717
    Almost all my wood is dead standing oak, that has sapwood turning punky. It will be fine for several years if top covered. I'm about 5 years out and growing.
  11. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    'Close' don't count 'ceptin horseshoes an handgernades! Keep choppin', could be some long, cold winters ahead! :D
  12. DNH
    DNH
    Missouri
    Great to hear it should last several years without any problems. It all depends on the weather this year, Im very comfortable I have enough for 16/17, 17/18 and maybe enough for all of 18/19.
    Today is opening morning of Deer season and I'm working if I can get an evening to unload before season ends I'll pickup another load of wood during lunch while I'm out hunting.
  13. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    There are two answers that come to mind and are in no particular order. First get a bigger burner or add one to a new area. Garages should be warm too. Second, sell some and put that money towards a new wood toy. :dex:
  14. stuckinthemuck
    stuckinthemuck
    As pointed out by Backwoods Savage part of the reason that we get 3 years ahead is because we don't always know that our current situation will allow us to stay ahead on firewood. Setbacks in health, needs of friends and family, changes in financial situation are all factors that could eat into our wood supply. While the stated goal is to stay 3 years ahead, the underlying requirement is simply to avoid scrounging straight from forest to stove which leads to inefficient burning of wet wood, a cold house, and need to switch to an alternative fuel source. Got a good wood savings account? Add to it!!!!
    Eric VW, savemoney, milleo and 6 others like this.
  15. The Wood Wolverine
    I'd would burn that this season. 90% of my hoard is in better "condition" which is why I say that. If it has any rot, it gets put in the basement first.
  16. DNH
    DNH
    Missouri
    Got it all unloaded, split a piece of oak 22" diameter and 18" diameter walnut put the moisture meter on to see what I wanted to do with it. Anyone want to take a guess what the MM reading is? This was cut ~3 years ago, long length piled loose good air flow in a field.
  17. fox9988
    fox9988
    NW Arkansas 72717
    Oak 45%
    Walnut 35%
    Eric VW, savemoney and Well Seasoned like this.
  18. swags
    swags Moderator
    Once I hit the three year mark I just try to keep up with replacing what I burn. I tend to go in spurts with cutting and splitting. I won't cut for a few months then go on a big cutting spree and stock a good bit up.
  19. DNH
    DNH
    Missouri
    Ill give a hint they were both the same.
  20. NH mountain man
    NH mountain man
    WMNF N.H.
    37.4 %
