Bucking Question
Discussion in 'The Wood Pile' started by MightyWhitey, Nov 6, 2016.
  1. MightyWhitey
    MightyWhitey
    How do y'all deal with a "Y" or a "Crotch" in the wood you're bucking into rounds??? Not a branch; but a definite split into 2 separate trunks.
    Where do you cut it, how do you cut it, and why do you cut it that way???
    Looking for a better way of dealing with these...............if possible. Thanks.
    Eric VW, Thor, Woodsnwoods and 3 others like this.
  2. Grizzly Adam
    Grizzly Adam Guest
    I just cut it where it makes a full length round
    Eric VW, Thor, Woodsnwoods and 7 others like this.
  3. Canadian border VT
    maple tree are famous for this... usually cut y at 16 (top and bottom y) .. and if splitter can't split it holds the brush pile down or gets thrown on top of stack uglies to hold top cover.. only lose 1 round and they split hard.. never stack well!
    BigPapi, Eric VW, Thor and 4 others like this.
  4. yooperdave
    I've got a lot of questions that I'd like some bucking answers to also!
    I have cut one side of the wye off as I would if I were limbing the trunk. I have also cut one side of the wye off so it would be square at each end of the piece. Not too often did I ever cut the wye off in a stove sized piece that still included both sides of the trunk.
    Usually split those anyway.
  5. bogydave
    Some I cut out the "Y"
    Some I cut to length & split (17")
    #1 : I decide that by how I think it will split & make a decent full length splits.
    Shape & size matter too. Hard to explain, After you've split a bunch, you get an idea of what the splits will look like.
    Also where the cut in the "Y" will be; if it makes 17" & is in the connected part of the "Y", I do that. But
    if the cut will be into the unconnected part of the "Y", I cut both off, just past the connected part &
    make the connected "Y" pice a shorty that usually ends up in the "Uglies" stack .
  6. red oak
    red oak
    I usually cut the y piece really short and then carve it up with the saw later, or try to split some sections off of it. You can also turn the saw sideways and cut into the y at the center, then cut down through and create two rounds right then and there. Or just cut it regular and throw it in the firepit.
    Eric VW, Thor, Woodsnwoods and 2 others like this.
  7. Oldman47
    Oldman47
    Illinois
    If you noodle the Y the resulting rounds are not too hard to split.
    Hinerman, bassJAM, unclefess and 7 others like this.
  8. Brett
    Brett
    Northwest Illinois
    I noodle a big piece with a "Y". Otherwise my splitter groans a bit but manages to nicely halve a "Y". I might end it with some ugly shaped pieces but it all stacks and burns.
  9. bogydave
    "Y"s are not too bad to split
    Was a thread on one site called "Splitting the crotch"
    Ole farm boy "Quads" showed how to do it, using his trusted maul.
    1st split, don't split the "Y" at the crotch, make 2 "Y"s from the bottom up to the "Y"
    Then split the "Y" down the middle
  10. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I cut as close to the v as I can to get a round on both sides.
    Eric VW, Thor, Woodsnwoods and 4 others like this.
  11. J. Dirt
    J. Dirt
    I usually cut tight to the crotch and then restart the firewood lengths and use the little crotch piece as an ugly for the shoulder basket
  12. MightyWhitey
    MightyWhitey
    And the bottom side????
  13. Pallet Pete
    Ovid
    O yes I forgot:whistle: I cut up to the bottom of the v then noodle it in half if I can. If it's too big I won't mess with the v.
  14. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I cut everything the same length and let the cut land on the mark. Then I split it on the splitter if needed. Any odd balls left after splitting go in the ugly bin. I like having the of shaped pieces at times as they help build out holes in the pile. If I split by hand, noodle that thing:dex:
    Eric VW and Thor like this.
  15. MightyWhitey
    MightyWhitey
    The BIG ones I've "noodeled" before. So I guess I'm doing something right.
    Thanks.
    Woodsnwoods and Eric VW like this.
  16. Mag Craft
    I just cut the Y off and then noodle up all the pieces and stack them.
  17. Shawn Curry
    Shawn Curry
    Western NY
    Ma nature usually delivers me whole trees. I don't end up with many Y's, because I usually limb the tree first, and I cut the branches off flush. When I do, I use the technique shown BogyDave's video. There is a plane of weakness aligned through the heart centers of the trunk and both branches. It's usually easier to split with the trunk end up, as shown in the vid.
    MightyWhitey, Thor and Woodsnwoods like this.
  18. BigPapi
    BigPapi
    The hills of Western MA
    I usually split a couple pieces off the outside if it won't split easily down the middle. The ugly leftover piece goes in the boiler whole. That is one thing the owb is certainly good for! It eats uglies just as well as "pretties." :D
  19. Will C
    Will C
    New York
    I cut them off flush to the main piece. I mark my 16" from the long side of the Y.
    Mag Craft, Thor and Woodsnwoods like this.
