Good deal!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Well Seasoned, Nov 5, 2016.
  1. Well Seasoned
    We had a customer switching from a wood stove to a gas stove. I helped with the install and found that the customer wanted to sell his fairly new Harman Oakleaf, with pipe and 3.5 cords of seasoned wood, all for $1000 bucks. We inspected the stove and it's in fine shape, so i pulled the trigger! I have the stove at the shop, need to order a hearth board and plan on picking up the wood tomorrow. It will take me 45 min per load x3 loads, but well worth it for the deal. I did snap a pic of the stove.
  2. Well Seasoned
    I'll also add, that although there is only a 1.7cu in firebox, the burn time is up to 17 hours of even heat with the 2 combustion cycles. :thumbs:
    DexterDay, jtakeman, raybonz and 11 others like this.
  3. Grizzly Adam
    Grizzly Adam Guest
    Are you handing out FHC business cards with the stoves? :sir:
  4. unclefess
    unclefess Guest
    thats great ,i recall you said you were starting a new job ,do you have stuff other than stoves where you work ? if you were a little closer i could help with some wood ,things are falling into place for you up there :thumbs:
  5. Well Seasoned
    There has been talk of incorporating FHC with what I will be doing, but this will be down the road a bit. :)
  6. Well Seasoned
    We are a Harman, PE, Morso dealer, along with mfg fireplaces, etc. Hearth pads, all the piping, CI goodies, mantles, etc.
    The original plan was setup a woodstove in the spring, but without one, I feel naked. I'll be getting 3.5 cords of seasoned wood, so I'm happy and set for this year. Now I can continue to process for next year and the year after. Wood is very expensive up here, so I got an amazing deal.
  7. Chvymn99
    Yea.... sounds like you've done good on that deal... Congrats!
  8. HDRock
    Wow ,that's a really good deal and a perfect for you with the wood, congrats :fire:
    A Quick search, I found the stove at $2300
  9. Well Seasoned
    Yea, base price is $2300...... mixed reviews online, and mostly user error. When the cat like part finally fails after 5 to 6 years, I can get it replaced at cost, so that's good.
  10. HDRock
    That wood is worth about 600-700 bucks around here
  11. Well Seasoned
    1. $ 825.00+here Basically getting the stove and stove pipe for $275 bucks! :makeitrain"
    Wood is expensive because the shavings are used for power, then pellets etc. Lots of log trucks running around.
    Selling firewood is the least of their concerns up here since they make good money other ways. So, price for wood goes up
  12. HDRock
    You got the chimney pipe too?
    clemsonfor, Horkn, Star Gazer and 3 others like this.
  13. Canadian border VT
    the seasoned firewood is worth a grand here so bought wood and got stove and pipe for free with some labor that's a win win!
  14. DaveGunter
    DaveGunter
  15. papadave
    Helluvagooderdeal! :thumbs:
    So, will this be used as a backup type deal or additional to something else in the house?
    I don't remember if you mentioned what kind of heat you have at the new place.
  16. Well Seasoned
    I only got the stove pipe and the cap. We used the existing class A for the new gas stove, lined for exhaust and inlet air within the class A. I should be able to get the class A I need at cost, as well as the ceiling support.
    I know, and the fact that it's seasoned is a bonus, meaning I can burn this season!
    :thumbs:
  17. Well Seasoned
    We have a pellet stove and oil backup. This will offset the cost of oil/kero too when it's real cold. The ducting runs along the water line, so this will help against frozen water pipes.
  18. concretegrazer
    concretegrazer
    Southwest MO
    Great deal! Is that a downdraft stove like the tl300? Looking forward to your review of it.
    raybonz, clemsonfor, Horkn and 4 others like this.
  19. Well Seasoned
    I think..... There is a cat like piece in the rear on the bottom. Front or top load with a bypass damper
  20. milleo
    milleo
    Price is right...Enjoy...And keep Maple and Saucy warm...:)
