5-ton electric log splitter deal
Discussion in 'Chainsaws and Power Equipment' started by raybonz, Nov 3, 2016.
  1. raybonz
    raybonz Moderator
    Carver, Mass.
    Harbor Freight has a 5-ton electric splitter for $229.00 right now.. Reviews look pretty good and the price is right..
    5 ton Log Splitter
    milleo, Doug, Hammy and 5 others like this.
  2. HDRock
  3. Horkn
    I've been thinking of getting an electric splitter for my parents and taking the gas splitter back home for my use.
    For my mom to just simply plug it in, and split mostly pine, I know they'd be good with that, if not better off than they are. She's not very good with small engines. She doesn't get the starting part very well, as she can't listen or feel when the motor needs gas/ choke/air when the motor is cold.
    milleo, Hammy, CTYank and 3 others like this.
  4. HDRock
    Well, that's a good price most of the 5 tons run at 300.
    There's a guy on the other forum that has one of these and likes it
  5. Horkn
    Yes also they took out the lopi endeavor wood stove and installed a jotul gas stove upstairs, so they only have the wood boiler downstairs, and that's only as a backup to the gas boiler. So they use a lot less wood than they used to.
    It's a lot less work to have the two 500 gallon LP tanks filled. They are both in their mid 70's.
    Hammy, eatonpcat, clemsonfor and 2 others like this.
  6. HDRock
    I still have my 7 ton, I was going to sell it but I'm keeping it for backup
    Hammy, raybonz, clemsonfor and 2 others like this.
  7. HDRock
    I bet they would like it, I miss the quiet, I used to sometimes split at night till 2 in the morning With the Electric.
    Much cooler at night in the summer
  8. HDRock
    If It's a little too warm out there in the daytime you already have power so you can do this:D:dennis:
  9. DexterDay
    Pretty good deal Ray!!
    Got me thinking real hard! I use my small Fiskars to split some during the winter down to kindling. This would make life very easy and I could do it in my basement (where it's warm!!)!!
    milleo, raybonz, Hammy and 1 other person like this.
  10. HDRock
    That would work out good because I am pretty sure that model has an on-off switch instead of a momentary push button, so it be would be one-hand operation, instead of 2 hand.
    Edit: yep it is one-hand operation on off switch
    Hammy likes this.
  11. HDRock
    You can put a block behind the pusher, ram deal, to keep it from returning all the way and it will save you some time.
    raybonz, milleo, Thor and 2 others like this.
  12. raybonz
    raybonz Moderator
    Carver, Mass.
    They're very quiet and only run when splitting. At this price it's hard to go wrong. I sit mine on an aluminum work platform.
    HDRock likes this.
  13. old 040
    old 040
    Buckeye State
    I've had one for several years now, still works well, would like to change the momentary switch to an on/off though, used it again yesterday with no problems.....:)
    HDRock likes this.
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    They do this for safety reasons. A footswitch would be great.
    HDRock likes this.
  15. HDRock
    The momentary switch on mine , stays on like this :):axe:
    blacktail, milleo, raybonz and 2 others like this.
  16. raybonz
    raybonz Moderator
    Carver, Mass.
    Hoping someone bought one of these splitters so we can know how well it works.. The electric splitters are very quiet and no maintenance..
    HDRock likes this.
  17. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    Works great, particularly on stringy wood. Pretty slow, so I prefer to hand split when I can. I will be replacing the wheels with bigger inflatables for more transport stability, and need to set up some sort of table arrangement to make it more convenient for long sessions. I am amazed at the power of the little thing! I have been able to stop it on some particularly narly stuff, but it shears through most that I have tried. Great supplement to the stable.
    When I called the number on the manual to get a replacement valve handle (accidentally discarded), they referred me to the number for Boss, so I guess they are made by the same place.
    HDRock and raybonz like this.
  18. Woodporn
    Woodporn
    S. MA
    if that has a momentary on off switch, how does the push plate return?
    HDRock likes this.
  19. raybonz
    raybonz Moderator
    Carver, Mass.
    Thanks for the review! I use an aluminum folding work platform I bought at lowes on black Friday for $20.00 to get it to a good working height.
    Easy Livin' 3000 and HDRock like this.
  20. HDRock
    Push plate returns when the lever is released , motor runs continuous so you have a free hand to position and hold the wood
    Easy Livin' 3000 and raybonz like this.
