Help with fresh air vent install - Whitfield Advantage II-T C FS
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Copernican Theory, Oct 31, 2016.
  1. Copernican Theory
    Copernican Theory
    MA
    Hello -
    New member and first post.
    I have a 1983 Whitfield Advantage II-T C FS and it runs great. I just purchased a fresh air (cold) intake kit and am very confused about installing it.
    I assumed (evidently incorrectly) I could just attach the new pipe the kit came with to back of the stove as it has a what I thought was a fresh air intake. I never checked to see if it was actually sucking air into the stove before I purchased the kit. So yesterday when I went to install it I notice there is no air current going in.
    I removed the rear cover and found that just inside and to the right is a round hole measuring about 1 1/2". I didn't measure it - it's about the same diameter as the intake on the back.
    This first pic is where I assumed I could connect the new pipe (rear of stove with the rear cover removed):
    This 2nd pic shows 2 things: 1. the other hole I found (to the left of the circled area) and 2. what appears to be a high temp cut-off switch (circled and labeled 'B') in yet another smaller hole. Sorry for the fuzzy pics - the camera wouldn't focus that close up.
    Here's where I am confused. When the blower is running neither of these two larger holes seem to be drawing any air. If you look into the 2nd hole (to the left of the circled area) you can see a 'wall' that blocks the passage. This does not make any sense. The cut-off switch is behind that wall, but is mounted in a smaller hole on the side of this ..umm.. square tube (I don't know what it's name is) as shown.
    The manual is worthless regarding any info about this.
    So now I have two problems: 1. No air being drawn in, and 2. even if there was air being drawn in, the second hole inside is still open and would just suck in air from the interior of the stove along with the outside air. Not exactly what I had in mind, but maybe there's a reason for it that I am unaware of.
    Now let me throw in one more confusing item: the blocking 'wall' is not completely blocking the passage. There is a gap on the bottom of this wall that I guess will allow some air in although I can't feel it, but it certainly does not match what is being exhausted out the hot vent.
    Angling my camera just right I was able to get a pic of that wall with the gap in this 3rd picture (circled and labeled 'A').. This is looking through the 2nd hole. The dark black line is the gap.
    I really don't know how this is supposed to work - why put an air intake on the back of the stove if it does not take in air? I always assumed that was where the air was being drawn in.
    If anyone can shed some light on what I'm missing I would very much appreciate it. Thanks.
    Roger
    ivanhoe and jtakeman like this.
  2. badbob
    badbob
    Lots of older stoves,and some new ones,are like that,they draw in a mixture of room and outside air.Is important to have all stove panels in place.Some can be easily modded to draw only outside(austroflamm)but do not think yours is.Do not know your stove well,but think what you are seeing in A is the air adjustment plate,hooked to the adjustment rod.
  3. Copernican Theory
    Copernican Theory
    MA
    Thanks for your reply.
    The adjustment rod is not connected to that. I've had to take the adjustment plate and rod apart a couple of years ago to free it up so I know that's not it. That blocking 'wall' is welded in place and cannot move.
  4. badbob
    badbob
    Ahh just a baffel then.Snowy here on this site knows those old whits,could send a pm.
    ivanhoe, jtakeman and will711 like this.
  5. imacman
    imacman
    Denver, NC
    Agreed.... Snowy Rivers is the person you need to talk to. She's the resident "old whitfield stove" expert.
  6. DexterDay
    Yeah. Lots are like this.
    They will draw from the point of least resistance . Which is outside (so long as the intake is not under a pile of leaves or snow/Why many do this).
    Keep your outside air hooked up. As long as the intake has no restrictions ,it will pull air from outside .
    Otherwise, it will pull through every other Crack in your home . Window leaks, door jams, outlets on external walls, etc.
    It's there for a reason and it works. I believe in OAK's . I have one on every stove in my home. Don't send heated air up the intake and out your exhaust
    ivanhoe likes this.
  7. Copernican Theory
    Copernican Theory
    MA
    I contacted Snowy as badbob and imacman suggested - thank you for that.
    Dexter, I am not debating whether to hook up an outside fresh air vent. I already know I want one - I just need to figure out how to do it.
  8. jtakeman
    Welcome aboard Copernican Theory
    Seems many of the early stoves had a OAK inlet, But left it indirect so if the oak was ever blocked(snow primarily) it still had a means to draw in air. I have seen some modify them to be direct. I suppose you could button up the inlet so it only draws air from the outside. There isn't much that would need to be done besides blocking the interior opening. Some sort of cap or plug to cover the hole??
    ivanhoe and SKEETER McCLUSKEY like this.
  9. Copernican Theory
    Copernican Theory
    MA
    jtakeman - I did think about that, but I cannot feel any air current being drawn into either or both of these openings. I don't know where the air is coming in. There must be some other opening somewhere.
    Hmm.. maybe the air flow is supposed to go into the rear fresh air connection on the back and flow out the other hole into the interior of the stove? It would still mix with 'house' air as there are lots of vents allowing house air into the interior of the stove. If that was the case I should be able to feel air being drawn into the rear intake - but I don't. So it still won't draw outside air.
  10. jtakeman
    That is a likely scenario. Member briansol has a similar dilemma with his Lennox. IIRC he had a stove repair tech come out and fab a sheet metal duct/channel to connect the inside to the out and made it a direct connect to the oak inlet.
    Are there other openings inside the enclosure? Some are even under the unit itself(quad?). If its another round opening you might be able to connect flanges and then run flexible duct inside the unit if you desire a direct oak?
    ivanhoe likes this.
  11. Copernican Theory
    Copernican Theory
    MA
    I guess I'll have to yank it out of the wall and poke around some more today. What's the best way to check air current - matches? Incense? Smoke bomb?
  12. jtakeman
    Are you a smoker, Cigar-Cigarette maybe? Smoke bomb might be a bit over...........
    Initial start up when the room fan is off might be the best time. Room fan inlet could throw ya a curve?
    imacman, ivanhoe and badbob like this.
  13. badbob
    badbob
    Yep a stick of incense will tell you whats going on
    ivanhoe likes this.
  14. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    He@@ where were you planing on setting that smoke bomb when you touch it off? I like to see that mess just for s&giggles :faint::doh::dex::rofl: :lol::eek::p:rofl: :lol::yes:.
    This is how you make friends with the wife.
  15. badbob
    badbob
    here ya go smokey---https://video.search.yahoo.com/yhs/search?fr=yhs-mozilla-004&hsimp=yhs-004&hspart=mozilla&p=smoke+bomb+in+stove+video#id=3&vid=274e25b945a2af180694722d0237a9c6&action=click
    ivanhoe and SmokeyTheBear like this.
  16. DexterDay
    Just take the burn pot out and follow that air channel back till you find where the air is coming in from.
    jtakeman, imacman and ivanhoe like this.
  17. badbob
    badbob
    lol some stoves (ussc) open up into a false bottom,and you have to caulk/seal the whole bottom to make a dedicated oak work,maybe others also
  18. DexterDay
    Quad Classic Bay 1200 is one of them. I owned one for years and sealed mine up.
    Just trace backwards !
  19. badbob
    badbob
    Yep, true,but not my search,just tryin to help out a member,hope things are well back there,stay warm!
  20. imacman
    imacman
    Denver, NC
    :faint:
    SmokeyTheBear, ivanhoe and jtakeman like this.
